Yep. Wonder how many times it can be said in the same thread?Baz999 wrote:I have this and my tread is 4mm. Use to have this also in my Scrooby when the tyres would get low. I put it down to the tyres and the 4wd system
Vibrating on Full Lock
Re: Vibrating on Full Lock
This happens when the tyre tread is low or wheels need alignment.
What tyres would you recommend?
Depends what mpg I was after. And how fast it goes down the strip.
- Simon the sparky
The Michelin pilot3 that I've just fitted have transformed my avant, the Dunlops were terrible!chunky79 wrote:What tyres would you recommend?
Current: RS4 Avant B7, Range Rover 4.4, VW up!, Fiesta ST van.
Previous: A3, S3, A6 Allroad, UR quattro, Porsche 3.2, Skyline R33 GTR,
Subaru WRX,
Subaru WRX,
Would terraclean help?
No Italian tune is far more effective, especially on full lock (in gear)chunky79 wrote:Would terraclean help?
- Surrey Sam
For a C5, Nankangditchfinders would be best.chunky79 wrote:What tyres would you recommend?
Boat hulls should be water tight, so no need.chunky79 wrote:Would terraclean help?
But what spacers should I fit?
That all depends on what brakes you'll be using.
Thanks for your help guys. I will get the alignment done first and take it from there. It happens on slow turns also, not just on full lock.
Mine scrubs on full lock, and i am guessing it is something to do with the car having drive to all four wheels, and there being a bit of fighting between the diffs etc.
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Alignment all checked today and it's all within tolerance.
I would assume it's definitely the tyres. Will burn through the current set and put some new rubber on in a few months
You won't fully get rid of it.
The joys of 19inch wheels with low profile tyres .
Users browsing this forum: No registered users and 149 guests
