Stupid questions
Plumb
Stupid questions
Post by Plumb » Wed Feb 03, 2016 11:45 pm
Hi new to all this Audi stuff, I have a b7 RS4 and have a few questions to ask which are very boring and easy for you people, without looking stupid I'll fire away.
Is carbon build up a job that I could do in my garage ? Or is it a specialist job only, I'm not afraid of working on a car.
Isn't there something like redex that could help reduce the carbon build up.
If I want my exhaust flaps open is it just a case of pulling the vacuum pipes off ? Do I have to blank the pipes off arterwards and blank the flap vacuum end up too ?
TAB1S
Re: Stupid questions
Post by TAB1S » Thu Feb 04, 2016 12:53 am
Hi bud have a look at the FAQ's at the top of the page, lots of help & advice there :thumbs:
Very easy exhaust mod yes just disconnect & plug the pipes, just look inside & make sure they are all open as they tend to get stuck.
Regarding carbon clean do a search as there's lots about it but in short yes many people do it them selfs & its not to difficult more time consuming.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift :mrgreen:
iainrs6
Post by iainrs6 » Thu Feb 04, 2016 10:11 am
Carrot
jaysrs4
Post by jaysrs4 » Thu Feb 04, 2016 12:30 pm
FedEx would probably do a better job with carbon build up than Redex!
PetrolDave
Post by PetrolDave » Thu Feb 04, 2016 6:58 pm
Plumb wrote:Isn't there something like redex that could help reduce the carbon build up.
This is an FSI engine so the injectors are in the combustion chamber, but the carbon buildup is in the inlet manifold - so no amount of additives to the fuel will make any difference at all.
Plumb wrote:If I want my exhaust flaps open is it just a case of pulling the vacuum pipes off ? Do I have to blank the pipes off arterwards and blank the flap vacuum end up too ?
You must plug the vacuum pipes or you will mess up the vacuum system that controls the inlet flaps and the "power flap" underneath the air cleaner - and lose the 5500rpm kick and quite a few bhp (up to 60bhp some say).
Plumb
Post by Plumb » Thu Feb 04, 2016 7:02 pm
So it's an unstoppable act then, when decoking is it just the inlet manifold to be done or do you do the ports down to the valves too ?
Is decoking a job for a brush or do you have a cleaning liquid ?
PetrolDave
Post by PetrolDave » Thu Feb 04, 2016 7:13 pm
Plumb wrote:So it's an unstoppable act then, when decoking is it just the inlet manifold to be done or do you do the ports down to the valves too ?
There's several threads with pictures and "How To" on here, best look at them before you tackle a CC.
It's hard so a brush will be pretty much useless.
Users browsing this forum: No registered users and 167 guests
