Rear heated screen problem
BiebaRS4
Post by BiebaRS4 » Sun Jan 24, 2016 4:11 pm
Afternoon gents,
My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
Thanks in advance,
Matt
PetrolDave
Re: Rear heated screen problem
Post by PetrolDave » Sun Jan 24, 2016 4:39 pm
BiebaRS4 wrote:My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
The heated rear screen is also used as one of the aerials for the radio.
To avoid interference on the radio there is a filter in series with the feed to the heated rear screen that separates the power from the aerial signal, I suspect that may be your problem - it's a not uncommon fault on Audis.
RSCosworth
Post by RSCosworth » Sun Jan 24, 2016 5:05 pm
Where is this filter located?? My heated screen doesn't work either plus my radio reception is terrible so I highly suspect this could be my problem too, what do you think?? :?
Mugello Blue B7 RS4 Avant, Black Optics, Buckets, FBSW, Carbon Inlays, Completely Standard
Previously owned:-
Nissan Sunny GTi-R
Renault Clio Williams
Ford Escort RS Cosworth
Renault Clio V6
Mitsubishi Lancer Evo 7
BMW M3 E46
PetrolDave
Post by PetrolDave » Sun Jan 24, 2016 5:23 pm
RSCosworth wrote:Where is this filter located?? My heated screen doesn't work either plus my radio reception is terrible so I highly suspect this could be my problem too, what do you think?? :?
Sounds like the likely culprit.
IIRC it's behind the trim above the rear window on the saloon, and behind the rear side trim (can't remember if it's LHS or RHS) on the Avant.
RSCosworth
Post by RSCosworth » Sun Jan 24, 2016 5:29 pm
PetrolDave wrote: Sounds like the likely culprit.
Nice one cheers buddy, will check it out :thumbs:
Previously owned:-
Nissan Sunny GTi-R
Renault Clio V6
BMW M3 E46
Users browsing this forum: Google [Bot], Squadr0n_ and 314 guests
