Tyre pressure monitoring system question
Demon
Post by Demon » Tue Jun 14, 2005 6:52 pm
This might seem a daft question, but then I'm a daft person.
Vehicle RS6 Avant
How can you tell whether you have a tyre pressure monitoring system fitted to the car, I've checked in the handbook and it is used in conjunction with the centre console menu button. Well I can't get this button to work so I assume that I haven't got the pressure monitoring system. However, since I recently took off a front wheel (to paint the inside of the wheel, but that's another story another day) and since the weather has got warmer, when I switch on the ignition there is a single bleep and the display shows a yellow tyre with a question mark but shows all four values, i.e. FL,FR,RL,RR etc not just one, it eventually goes out as I am driving home. This never happens in the morning, only after work when the car has been standing all day.
All of the tyre pressures are ok.
Has anybody got any ideas ?
wboard
RE: Tyre pressure monitoring system question
Post by wboard » Tue Jun 14, 2005 9:37 pm
Your car will have tpms. The menu button should work when car is stationary, although i think if a major fault is logged it will not work untill this has been rectified.
W8PMC
Post by W8PMC » Wed Jun 15, 2005 9:38 am
My menu works when the car is stationary or moving. ALl RS6's IIRC have the menu/DIS function & although not positive, i'm pretty sure the tyre pressure monitoring is also standard. I've had the warning a few times & indeed the pressures have been slightly lower than they should be. I've only ever had all tyres displayed as i don't think the system can determine or show if only 1 tyre is the wrong pressure.
Its possible that your's has not been set-up correctly, so perhaps a trip back to the dealer is in order, although the handbook does detail how to set-up the warning system.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
londonplus
Re: Tyre pressure monitoring system question
Post by londonplus » Wed Jun 15, 2005 11:52 am
Demon wrote:This might seem a daft question, but then I'm a daft person.
Vehicle RS6 Avant
i had the same problem re. the button when i first got mine. press it where it says menu rather than pressing the actual knob.
re the pressures it is giving you the warning because of a change in atmospheric pressure due to the weather - on the occasion that all four values show up i dont normally worry about it -as you say they go off after a while. alternatively go to your dealer and he can show you how to reset although you can do this yourself once you have mastered the menu button!!
Demon
Post by Demon » Wed Jun 15, 2005 1:00 pm
Well, you learn something new everyday, I didn't even know there was a switch where it says "menu" I've had a quick play during my lunchbreak and it seems that I do have a menu.
Will play again tonight. Thanks for the input everybody
Steve
londonplus
Post by londonplus » Wed Jun 15, 2005 4:54 pm
Steve
pleasure to have been of assistance - thats the beauty of rs246.com! :lol:
Jeeves
Post by Jeeves » Wed Jun 15, 2005 10:04 pm
Vehicle RS6 Avant
Brilliant - and thanks too.
I've just been using it as a mount for a car kit microphone and was really wondering why they'd bothered putting a redundant knob where a really useful slot was. :shock: Should have read the manual a bit better! :wink:
gord
RE: Re: Tyre pressure monitoring system question
Post by gord » Thu Jun 16, 2005 1:55 pm
In my experience you will soon know you have them fitted because they flash on all the time for no reason!
I just ignore it and check the pressures regularly.
GM
EuroSag
Post by EuroSag » Thu Jun 16, 2005 11:21 pm
I agree with the above, just check the pressure's regularly using the old fashioned method!! :wink:
Mine have been disabled in the menu anyway.
Porsche 997 GT3 - 2010/60
Porsche 997 GT2FS - 2008/58
Peugeot 205 1.9 GTI-S - 1991/J
Audi B7 RS4 Saloon - 2007/07
Audi Q7 3.0TDI - 2011/11
Alfa 147 GTA - 2003/53
Ford F150 Raptor - 2012/62
SimonS4MTM
Post by SimonS4MTM » Fri Jun 17, 2005 11:59 am
Not sure how Audi have configured the system to work on their cars, but the TPMS ecu will have to carry out a learn function form time to time. This may de done automatically or manually by pressing a button on the dash.
When the TPMS carries out a learn function, it will store the pressures of all 4 wheels and determine which wheels are fitted to which corners of the car. If it then detects a pressure loss below a pre programmed threshold ie puncture, a warning will show on the dash.
If a learn function is not performed regularly then false warnings will be given ie after you have inflated or deflated your tyres.
Users browsing this forum: philS2 and 179 guests
