Sure seems so but we are selling many every month so tuners think there still worthy and they had many specs from us inc tte8xxPaulm wrote:Yeah but until someone sorts out the Charge cooler bottle neck there is little point going for the bigger turbos.
hopefully there will be something by the time I start looking for turbos
800bhp + DIY Project
Re: 800bhp + DIY Project
So someone is making progress? I wont need turbos until mid year, see what transpires by then
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
So are those coolers 'behind' the radiator!? That cannot be good, ne?
They're charge coolers, not intercoolers so they don't use air flow to cool but use coolant (water?) instead. The coolant in the charge cooler is then cooled by a small radiator just infront of the main radiator at the bottom.
good compact design just no fun for tuning
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Hmmmm, just looking at that diagram, it looks ripe to use Phase Change cooling.
- Step 1 - Beef up OEM aircon package
Step 2 - Redesign cooling jacket for the cooler
Step 3 - Route into newly beefed aircon
Step 4 - ??????
Step 5 - Profit
There are options out already to increase cooling but from what I have read its flow that is stopping cars getting over 800bhp. I know forge are looing at a bigger radiator and reservoir to help cooling but no-one has addressed the flow side of thing that I can find?
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Do you mean an engine coolant radiator and reservoir? I was taking about the charge cooler (some call it these intercoolers) having a better efficiency.Paulm wrote:There are options out already to increase cooling but from what I have read its flow that is stopping cars getting over 800bhp. I know forge are looing at a bigger radiator and reservoir to help cooling but no-one has addressed the flow side of thing that I can find?
Anyways, is flow or cooler volume the issue?
If it's flow, is that the pre-cooler intake flow or the 'flow' from the cooler itself and/or supporting pipework? i.e. where is the bottle neck.
If it's volume then that's an issue, there's just no where extra/larger charge coolers can go. It'll end up being the "radiator in the boot combined with a FMIC a la Quattro Sport S1" style solution.
No doubt someone will figure out the sweet spot of air blocking the radiator in combination with a FMIC.
All summation and bro science, of course.
Bam - The charge cooling has it's own reservoir and radiator which is separate from the engine coolant res/rad setup. It is these that are being made bigger to help the small charge cooler work more efficiently by getting more coolant through the charger cooler and then cooling it faster by using a much bigger rad.
However, the 900+ hp issue is mainly air flow through the Charge Coolers (restricted pipework diameter/bends is the biggest issue) and also volume, but that's to a lesser extent, although bigger is always better
thanks Ian, I did not explain myself very well
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
- GTM Bandit
Im planning out a swap for my 2009 S5. After all my research at this time, an Air to Air intercooler may be the true answer. If you're planning on keeping that half a shoebox Paul, you should look into water meth.
The sportmile c7 did drop the charge cooler and go air to air.
Ahhh, got it. So it has its own circuit, that's awesome. So the remit should be to increase the charge cooling circuit output while making the core more free flowing? I see how the pipework is an issue.IanH755 wrote:Bam - The charge cooling has it's own reservoir and radiator which is separate from the engine coolant res/rad setup. It is these that are being made bigger to help the small charge cooler work more efficiently by getting more coolant through the charger cooler and then cooling it faster by using a much bigger rad.
Bigger isn't always better with charge coolers, if it's too big you'll tkae an age to make pressure, certainly not a problem here! I'd bet some tuners are just thinking about stuffing a huge single turbo into the V to minimise pipework.
I'm out. I need to sit in front ETKA for this beast, very interesting.
- MartayMcFly
- 5th Gear
bam_bam wrote:
- Step 4 - ??????
Step 5 - Profit
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
Users browsing this forum: Google [Bot] and 57 guests
