Will these fit?
lardy
Will these fit?
Post by lardy » Sun Jan 10, 2016 10:15 pm
Hope someone can help, i'm looking at buying somes wheels with winter tyres from another forum member but want to know if they will fit my B7 RS4.
Ronal 8" x 18"
- Part #: 8K0 601 025Q
- PCD 5x112
- Offset ET47
- Centre bore 66.6mm
Will these fit?
Going snow hunting in Febuary through the Alps and want to be prepared, many thanks.
RichieRS
Re: Will these fit?
Post by RichieRS » Sun Jan 10, 2016 10:29 pm
From my limited knowledge I would suggest that you will need spigot rings to change the centre bore size (the b7 is 57. Something!!)
Also the offset is very high so will sit well inside the arch. Spacers may be required perhaps?
Not sure if you will have caliper clearance issues with that offset on 18"x8"s too?
lardy
Re: Will these fit?
Post by lardy » Sun Jan 10, 2016 10:37 pm
Thank Richie, I think I do need 57.1mm spigot as the seller mentioned that to, thanks for the reply, now I just need to know if they will clear the calipers???
iduff
Re: Will these fit?
Post by iduff » Sun Jan 10, 2016 10:49 pm
I have Kahn 18x8 et33, and there's only a couple of mm radial clearance from the front calipers. My guess is you will need to try fitting them and see, or get someone who has tried them to fill you in.
With that amount of offset, you might have axial clearance issues as well, but a set of spacers would likely fix that and the hub bore issue. BTW, your RS4 hubs are indeed 57.1mm, and the OEM 9" wide wheels are et29.
HTH.
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
MB2
Re: Will these fit?
Post by MB2 » Mon Jan 11, 2016 12:43 am
OEM winters which clear the calipers are 7.5 ET 21 the ones you are looking at are 8 ET 47. This will give you 32mm less inner clearance so I would say they will not fit.
psglas
Re: Will these fit?
Post by psglas » Mon Jan 11, 2016 12:44 am
I have the A5 equivalent as my winter wheels and they fit but only just. There is only just enough space for the caliper and I have a spigot ring because of the bore different. There's a bit of a difference in the offset and they are a bit wider. I would try before you buy if you can.
8T0601025M
ET 29
PCD 5x112
8.5J x 18
66.6mm
MartayMcFly
Re: Will these fit?
Post by MartayMcFly » Mon Jan 11, 2016 4:19 am
Standard wheel is 9J ET29, so would need 30mm spacers to sit the same at the face, and at least 5mm to sit the same inside. I'd imagine you'll need spacers to clear the calipers anyway, but that's much more trial and error unfortunately as spoke design plays a big part.
And you'll need spogot rings as people have said.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
MB2
Re: Will these fit?
Post by MB2 » Mon Jan 11, 2016 1:35 pm
Maybe see if these are still available - they would fit !
viewtopic.php?f=35&t=113958&p=759563&hi ... er#p759563
Users browsing this forum: Bing [Bot], Google [Bot] and 259 guests
