Tom tom poor signal
Re: Tom tom poor signal
Post by Shoppinit » Fri Jul 25, 2014 12:27 pm
It might be hidden behind the module which is screwed to the bulkhead behind the glove box. Memory is failing - it's been 5 years since I did it!
I seem to remember the grommet being very long on the engine side. Plenty big enough to get a coat hanger through and the GPS antenna socket back inside the car, though.
Steveo
Post by Steveo » Fri Jul 25, 2014 12:37 pm
There was a large loom tucked behind that module. I will remove it tomorrow morning and see if that brings any joy.
Thanks Shoppinit
RS6 C5, MTM
rtd
Post by rtd » Thu Dec 31, 2015 9:42 am
Folks would this also help to say boost the gps signal for a speed camera detector? My snooper is not getting a decent gps signal in my c6 need to boost the signal inside car so that it can get a good gps lock.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Post by Shoppinit » Thu Dec 31, 2015 10:20 am
Yes. It amplifies the GPS signal and sends it round the car. Anything at uses GPS will benefit.
rtd
Post by rtd » Thu Dec 31, 2015 10:23 am
Brill thanks Shop
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Gripper1
Post by Gripper1 » Thu Dec 31, 2015 11:08 am
I had this issue with mine as it has the solar reflective glass.
Easiest and cheapest way was an eBay GPS puck and run to the back of the car and tucked into the corner of the nearside glass behind the rear passenger seat. It doesn't appear to have the reflective coating there so I get a decent signal.
All in £10 and 10 mins tucking the wires behind the internal plastic sill panels.
rtd
Post by rtd » Thu Jan 07, 2016 3:26 pm
has anyone done this on a C6 as this thread is c5 focused.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Post by Shoppinit » Thu Jan 07, 2016 4:00 pm
No reason why it shouldn't be exactly the same. The C6 also has a 75X terminal for switched 12V.
rtd
Post by rtd » Thu Jan 07, 2016 9:16 pm
Shoppinit wrote:No reason why it shouldn't be exactly the same. The C6 also has a 75X terminal for switched 12V.
Hi shop, was just wondering about how I can feed the ariel into the engine bay to get it behind the grill or somewhere suitable to get a signal
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Post by chunky79 » Thu Jan 07, 2016 9:20 pm
There will be a rubber grommet some where in the cab compartment for you to feed the wire through into the engine bay. You just gotta find it.
Post by Shoppinit » Thu Jan 07, 2016 9:21 pm
There's bound to be a big grommet with a big fat bundle of cables running from the engine bay through the bulkhead into the cabin. I bet it's in the same place as the C5 but you should be able see it from inside the engine bay.
rtd
Post by rtd » Thu Jan 07, 2016 9:23 pm
Thanks guys
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Post by chunky79 » Thu Jan 07, 2016 9:24 pm
Shoppinit wrote:There's bound to be a big grommet with a big fat bundle of cables running from the engine bay through the bulkhead into the cabin. I bet it's in the same place as the C5 but you should be able see it from inside the engine bay.
Tooooooooo slow.
rtd
Post by rtd » Thu Jan 07, 2016 9:34 pm
Tooooooooo slow.
Chunky you still got your misano c5? I remember when you got it
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Post by chunky79 » Thu Jan 07, 2016 9:36 pm
Yup. You remember when I got it? I've almost forgotten that :lol:
Users browsing this forum: Google Adsense [Bot] and 96 guests
