Urgent assistance requ FUEL PUMP MODULE CONTROL CIRCUIT LOW"
5.0 V10 50v biturbo - 571 bhp
dave81uk
Post by dave81uk » Fri Dec 25, 2015 6:16 pm
Merry Christmas all
I've just changed my battery on my c6 as it was a little low.
I have changed it for a Bosch and it did have a vatara.
I used a set of jump leads to connect to another battery while I disconnected & reconnected.
I've read something about coding the batteries but will this need doing?
I started the vehicle after connecting the new battery with jump leads disconnected and it started all fine.
Next day (today) I come to start today and it will only turn over and not fire.
I have a general obdII code reader and it is given a code of P025C " FUEL PUMP MODULE CONTROL CIRCUIT LOW"
I'm supposed to be going away in a day or so so if really appreciate some help as all dealers will be closed obviously
May thanks in advance
Dave
07764478534
dave81uk
Re: Urgent assistance requ FUEL PUMP MODULE CONTROL CIRCUIT
Post by dave81uk » Fri Dec 25, 2015 10:24 pm
Ok sorry so I've got it sorted.
There in a 30amp fuse connected to the battery terminal which is a little poor design really as when you take the positive terminal off the battery you break the fuse link - unless you know it's there and are very careful
I assume it runs to the fuel pump or fuel pump module
For now I dropped a blob of solder over the break in the fuse and hey presto
Will get w new fuse from the stealers when they open - probably a tenner
If I can find out how to put a picture on here I'll post one on of location & break in the fuse
leet
Post by leet » Fri Dec 25, 2015 10:49 pm
dave81uk wrote:Ok sorry so I've got it sorted.
The fused link was circa £6 if I remember rightly. It wasn't a stock item though.
NeilRS06
Post by NeilRS06 » Tue Nov 21, 2017 10:48 am
Have you got a picture of this fuse mate I have exactly the same problem with new battery
