Warm Key
- Graeme4130
Warm Key
Hi all
Sounds like a silly question, but does anyone else's key come out the slot warm ?
I've noticed mine has been quite hot the last couple of times I've removed it, and having had this car through one winter already, I don't recall it doing it last year when i would've had the heater on in a similar manner
Maybe I just forgot from last winter, but it does seem to be quite hot recently
Re: Warm Key
Sounds like the car is set on defrost mode, if you look under the car behind the rear offside wheel, you will find a red button.. Just push it to turn off
- Graeme4130
Re: Warm Key
Haha, I knew you'd know the answerRIV wrote:Sounds like the car is set on defrost mode, if you look under the car behind the rear offside wheel, you will find a red button.. Just push it to turn off
Re: Warm Key
I never use my key so I can't help on the heat issue, as I have never liked the push key setup in the B8 Audi's - couldn't understand why they changed from the standard ignition key (and push button start in the B7 RS4). Went for the advanced key in the B8 - like the push button start /stop instead of messing about with a key....
Driven plenty of A4's using this type of key but never noticed the key getting warm at all....
- RossDagley
- Top Gear
Re: Warm Key
Biggest issue I have with advanced key is where to put the key if not in the slot! Cant use the cupholder as then where does your drink go. I have a good sized bunch of keys so dont like keeping them in my pocket either. So in the slot it generally goesjohnnydog wrote:I never use my key so I can't help on the heat issue, as I have never liked the push key setup in the B8 Audi's - couldn't understand why they changed from the standard ignition key (and push button start in the B7 RS4). Went for the advanced key in the B8 - like the push button start /stop instead of messing about with a key....
Previously:
Previously:
Re: Warm Key
Fine, but what about the key?RossDagley wrote:So in the slot it generally goesjohnnydog wrote:I never use my key so I can't help on the heat issue, as I have never liked the push key setup in the B8 Audi's - couldn't understand why they changed from the standard ignition key (and push button start in the B7 RS4). Went for the advanced key in the B8 - like the push button start /stop instead of messing about with a key....
Re: Warm Key
Slam dunk... that was asked for...... twice ;
Re: Warm Key
WTF is that all about? I assume you are just kidding?RIV wrote:Sounds like the car is set on defrost mode, if you look under the car behind the rear offside wheel, you will find a red button.. Just push it to turn off
Re: Warm Key
I thought the idea was to keep it in your pocket or handbag (if you feel the need to carry one?!?). I also guess that if you were unlucky to get your car hijacked, the would be car thieves wouldn't realise they haven't got a key for the car until they are well away with it and you are out of their reach. I presume that the car will continue to run until the engine is switched off, and obviously then they would be knackered.....or is there a range that the car will run without the signals from the key fob?
Re: Warm Key
Key has to be absolutely in the car for it to start.johnnydog wrote:I thought the idea was to keep it in your pocket or handbag (if you feel the need to carry one?!?). I also guess that if you were unlucky to get your car hijacked, the would be car thieves wouldn't realise they haven't got a key for the car until they are well away with it and you are out of their reach. I presume that the car will continue to run until the engine is switched off, and obviously then they would be knackered.....or is there a range that the car will run without the signals from the key fob?
Re: Warm Key
I believe it will continue to run until it is turned off.johnnydog wrote:I thought the idea was to keep it in your pocket or handbag (if you feel the need to carry one?!?). I also guess that if you were unlucky to get your car hijacked, the would be car thieves wouldn't realise they haven't got a key for the car until they are well away with it and you are out of their reach. I presume that the car will continue to run until the engine is switched off, and obviously then they would be knackered.....or is there a range that the car will run without the signals from the key fob?
- RossDagley
- Top Gear
Re: Warm Key
Yes it runs until it's turned off but you are warned promptly on the dash when the key departs the vehicle.
Previously:
Previously:
Re: Warm Key
Behind the cup holders you'll find there's an armrest. That actually lifts up and there is a compartment underneath. Your keys would more than likely fit in there with out any issues. Unless you're a caretaker with a lot of responsibility........RossDagley wrote: Biggest issue I have with advanced key is where to put the key if not in the slot! Cant use the cupholder as then where does your drink go. I have a good sized bunch of keys so dont like keeping them in my pocket either. So in the slot it generally goes
I always have my key on its own. I never have my house, car or office keys together, because I'm a clot. If I loose one, I've lost them all, so I keep them all separated. I also hate rattles, so having things hang from the car key would drive me nuts, plus over time potentially scratch and damage the immediate dash area...
It's all torque talk.
- RossDagley
- Top Gear
Re: Warm Key
Then where would I keep Mrs Smudge's spare underwear?smudge wrote:Behind the cup holders you'll find there's an armrest. That actually lifts up and there is a compartment underneath. Your keys would more than likely fit in there with out any issues. Unless you're a caretaker with a lot of responsibility........RossDagley wrote: Biggest issue I have with advanced key is where to put the key if not in the slot! Cant use the cupholder as then where does your drink go. I have a good sized bunch of keys so dont like keeping them in my pocket either. So in the slot it generally goes![]()
Previously:
Previously:
- Graeme4130
Re: Warm Key
Even I know Mrs smudge doesn't wear any underwear
Users browsing this forum: No registered users and 71 guests
