Buckets to comforts with memory
ians63
Re: Buckets to comforts with memory
Post by ians63 » Wed Dec 16, 2015 12:15 pm
pDkALO wrote:As you say, illuminated button sounds positive, as it's clearly connected up
You're certain that you've got the correct window motor with the 8H prefix and all of the connection pins? (not some blanked out as on a standard car)
I tried a 8H widow motor with the same results - this also made the windows erratic so I think that's a non starter.
PetrolDave
Post by PetrolDave » Wed Dec 16, 2015 1:25 pm
Have you done all the steps in the "How To" pdf I shared, including connecting the CAN bus?
ians63
Post by ians63 » Wed Dec 16, 2015 5:50 pm
PetrolDave wrote:Have you done all the steps in the "How To" pdf I shared, including connecting the CAN bus?
According to the guide pins 5 6 7 are used for the CAN connections. These pins are already wired in so I was hoping it would just be plug and play. Looks like I'll be under the carpet and into A pillar wiring for a bit of investigation.
ians63
Post by ians63 » Fri Dec 18, 2015 12:00 am
Had a look at wiring tonight.according to the guide;-
"The wiring order is as follows;
 T10o/6 to orange/green (or/gn) for CAN Comfort High,
 T10o/7 to orange/brown (or/br) for CAN Comfort Low and
 T10o/5 to green/black (gn/sw)"
Pin 6&7 are wired as per the guide already. Pin 5 is brown (earth). There is no green and black wire coming from the door to connect to.
ians63
Post by ians63 » Fri Dec 18, 2015 12:16 pm
Does anyone on here have access to a wiring diagram that would apply to the set up I'm trying to achieve - i.e 2006 A4 B7 memory seats?
Surrey Sam
Post by Surrey Sam » Fri Dec 18, 2015 12:56 pm
I can try help out a bit later, seems that you’re rather close.
Any particular component you need the diagram for? There won’t be a big overview for the system unfortunately.
ians63
Post by ians63 » Fri Dec 18, 2015 1:05 pm
Probably just from the door controller to the car dist system I'm just curious as to what the green and black wire referred to in the guide is for.
iduff
Post by iduff » Sat Dec 19, 2015 7:56 pm
Here's what my US (driver's side on the left) seat measuring blocks say in VCDS
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
ians63
Post by ians63 » Wed Dec 23, 2015 12:46 pm
Finally got this to work. Combination of missing green / black wire (see previous post for guide) from window regulator to seat power connecting red block and a dodgy Stop / Off switch not latching down (easily spotted in VCDS - once I knew where to look) I put a jumper wire in to test and gave the switch a good spray of contact cleaner and voila memory seats.
Next issue is dipping passenger mirror in reverse not working - anyone have any clues about his one. Not even sure if it's meant to do this, some forums aye some forums naw.
Not massive mods but nice to have.
iduff
Post by iduff » Wed Dec 23, 2015 2:05 pm
Perhaps stating the obvious, but you need to have the passenger mirror selected on the adjustment control switch.
CPO, stock
Former Quattros
Surrey Sam
Post by Surrey Sam » Wed Dec 23, 2015 2:16 pm
Sorry :oops:
I knew there was something that I had recently forgotten to do.
Here is the wiring diagram for the mirror if that's of any use, well done for getting the seats operational.
Users browsing this forum: No registered users and 344 guests
