Flashing Esp light on hard acceleration
Promech
Post by Promech » Fri Dec 18, 2015 6:14 pm
Hi, wondering if anyone has had this. I've never had the esp light flashing for traction on hard acceleration before but I'm now getting it constantly on heavy acceleration. I have recently had tyres replaced on rear but I'd be surprised if they would spin up all the way through gears on Quattro system, anyone experienced anything similar ( recently had gearbox rebuilt due to failure and a little worried it's a gearbox issue)
Mɐʇʇ
Re: Flashing Esp light on hard acceleration
Post by Mɐʇʇ » Fri Dec 18, 2015 9:11 pm
Happy to be corrected, but I can't think of a circumstance how it could be gearbox. I can think of lots of circumstances where it could be electrical related though - one of the plugs jogged on the way out/in with the engine etc. Probably time to plug VCDS in.
Post by Shoppinit » Fri Dec 18, 2015 10:15 pm
Could be bad load calculations due to mixture problem.
How is your idle?
a Vagcom is going to be useful to diagnose.
LunarWolf
Post by LunarWolf » Sun Jan 24, 2016 12:20 am
Is the car modded in any way?
If so, Often, there is a mismatch error with what power the engine tells the ECU it puts out and what the wheels tell the ECU they are receiving.
This means that the ECU thinks the wheels are spinning faster than the vehicle is travelling (i.e wheelspinning).
However, when that happens, the ECU DOESN'T cut the power like it would if one wheel was spinning (i.e skidding).
I think that made sense? Usually, a short trip to your re-mapper should correct that.
Obviously, there are other reasons why this can happen.... the above is only my experience thus far.
I've finally got my head together but now my body is falling apart!
Jultsu
Post by Jultsu » Sun Jan 24, 2016 7:58 am
The replacement tyres were identical in size, and pressures have been checked as well in all four corners?
Users browsing this forum: Google [Bot] and 53 guests
