Sat Nav Plus Firmware Update?
Golfather
Post by Golfather » Sun Jun 05, 2005 2:01 pm
Hi
Does anyone know where I can download the firmware update to upgrade a SatNav Unit on a B5 RS4?
There used to be a site tvwiz.net but dont think that exists now.
Thanks in advance
dazzer
Post by dazzer » Sun Jun 05, 2005 3:52 pm
Naaaaaa - you haven't - have you?
Dazzer
Dippy
Post by Dippy » Mon Jun 06, 2005 12:36 pm
I'd be surprised that an RS4 SatNav didn't have the latest software, but in case your's doesn't, it is available here: http://www.nav-plus.com/instructions/software.html
FYI Dan (TVWIZ) was forced by AoA to close his site. I believe this was because of the instructions on how to create a backup copy of a Nav CD.
2001 Silver S4 Avant
Golfather
Post by Golfather » Mon Jun 06, 2005 1:46 pm
Excellent thanks Dippy.
I actually found this site last night as well as others: http://www.navplus.us/ http://www.vwnavi.com/vwnavi/forums/
and noticed some of you guys also post there.
Lots of useful info there.
My firmware was Dec 2000 so needed the Nov 2001 update.
Got the firmware updated, but had to burn the disc at 4x for it to work.
Dazzer, yes I have :D
ChipHazzard
Post by ChipHazzard » Thu Jun 09, 2005 8:49 am
Gents
Can anybody give me a clue as to what Nav+ system would've been fitted to my 99 fl S4 Avant with TV as it has a 99 firmware release on it and if possible i'd like to try and update it. Also can anyone suggest what is the latest release Nav disc i can run as i currently have a 01 disc in it
Cheers in advance
Dippy
Post by Dippy » Thu Jun 09, 2005 12:15 pm
If your car is a facelift, it should have the 'D' Navi. However you do need to be sure because if you try to upgrade a 'C' Navi it may die!
I theory it should be possible to determine which you have from the 'hidden' software screen, but I don't know how to interpret the numbers. What I can tell you is that you can tell from the Navi model number, which will be on a sticker on the side of the unit (so if you have the 4 keys you could release it far enough to see).
8D0 035 192 D or lower is 'C' Navi and should not be upgraded.
8D0 035 192 E or higher is 'D' Navi and may be upgraded.
If it is a 'D' Navi then it can read the latest DX CDs from Teleatlas (www.navshop.com)
ChipHazzard
Post by ChipHazzard » Thu Jun 09, 2005 12:50 pm
Thanks Dippy i'll have a look when I get home tonight but i do know it wont read DX cd's so i guess it must be a C Navi ........ the car was orginally a personal import
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
Dippy
Post by Dippy » Thu Jun 09, 2005 12:57 pm
If you know it won't run DX disks then yes it IS a 'C' Navi. You can swap it for a 'D', but there are pitfalls (as well as cost) so you'll really need to want the benefits (such as TMC).
ChipHazzard
Post by ChipHazzard » Thu Jun 09, 2005 2:32 pm
Without wanting to sound too much like the newbie S4 owner i am (approx 2 1/2 months now) what are tha actual differances and would I be correct in assuming that any non dx CD should work
FL Noggy S4 Avant
Dippy
Post by Dippy » Fri Jun 10, 2005 2:23 pm
Yes, but you'd be pressed to find an updated non-DX disc unfortunately.
CliveH
Post by CliveH » Wed Jul 15, 2009 12:11 pm
Resurrecting a very old thread here, I know, but does anyone have a current link to the latest RNS-D firmware please?
(the links above no longer work)
Clive
Return to “Electrical”
