RS6 Performance Edition is Open to Order.
doodlebug
Re: RS6 Performance Edition is Open to Order.
Post by doodlebug » Sat Dec 12, 2015 9:42 pm
Figures....but does it have the full functionality?
PSB1
Post by PSB1 » Sat Dec 12, 2015 9:43 pm
doodlebug wrote:Exclusive paint will bugger up build times.
I'm not sure PE has so much more that it's going to make a material difference, there's no more torque. Still, i'd take DRC every time with the C7.
Understood - my thoughts there are that it may just be one of those 'expected' boxes to have been ticked when it comes to re-sale. I could handle a long-ish build as I want 6 months at least with the B8.
doodlebug
Post by doodlebug » Sat Dec 12, 2015 9:44 pm
Maybe. Though actually I'd steer clear of exclusive paint. The one car I had suffered horrendous lacquer peel!
boff
Post by boff » Sat Dec 12, 2015 9:54 pm
must have been friday when applied
Zero Drama
doodlebug
Post by doodlebug » Sat Dec 12, 2015 9:55 pm
boff wrote:must have been friday when applied
Agreed! But it's not unique either. It was a complete and utter ball ache to have it sorted.
boff
Post by boff » Sat Dec 12, 2015 10:07 pm
i'd want acc using the radar
Zero Drama
kmpowell
Post by kmpowell » Sat Dec 12, 2015 10:16 pm
doodlebug wrote:Figures....but does it have the full functionality?
Not sure. He only did the coding a couple of days ago and I've not spoken to him since. I'll bell him tomorrow to find out.
'15 B8 RS4 - SOLD
Eddie555
Post by Eddie555 » Sat Dec 12, 2015 10:31 pm
kmpowell wrote:
MikeFish wrote:Pretty sure the speed limit display is just a VCDS code change
It is. A friend of mine has activated a load of things on his new TTS, using VAGCOM...
High beam assist
Adaptive Cruise
Speed limit display
Traffic Sign Recognition
I'm only wondering but can you also ask him if the night vision is possible???
Current ride’s
Previous rides
doodlebug
Post by doodlebug » Sat Dec 12, 2015 10:33 pm
High beam assist
Adaptive Cruise
Speed limit display
That's another camera surely.
Heden
Post by Heden » Sat Dec 12, 2015 10:50 pm
kmpowell wrote:
doodlebug wrote:Adaptive implies the radar was fitted. Isn't as a matter of course on anything else I know.
ACC works in two ways. The first is by using the front camera and the radar then merging the two data streams together, the other way is the same as used on the VW golfs which just runs off the front camera, the SAME camera that's fitted to the TT. So it means you can also add things like traffic recognition as well... all runs off the one device.
Also please bear in mind that the new TT is a complete different platform. The C7 doesn't come with any camera and or radar unless you spec the assistance pack. Granted that maybe speed limit can be coded (if you have speced the assistance pack).
Regards,
Niclas
Eddie555
Post by Eddie555 » Sat Dec 12, 2015 10:53 pm
Regards,
Niclas
I'll correct you there. The FL C7 has a camera under the rear view mirror. I believe this is for the matrix led headlight assist.
Current ride’s
Previous rides
wildbore
Post by wildbore » Sat Dec 12, 2015 11:26 pm
There is no such thing as ACC driven off just a camera on any car, ACC requires radar as a minimum. I am pretty sure that ACC also uses the ultrasonics on the C7 platform, and Speed Limit Display and Traffic Sign Recognition are the same thing. Last time I looked at the VCDS thread it had not been possible to get Speed Limit Assist coded up successfully via VCDS but that may have changed since then, and Night vision definitely uses it's own dedicated infra-red camera mounted in the front rings.
Post by MikeFish » Sat Dec 12, 2015 11:37 pm
The cost of night vision would suggest it is a hardware addition but pretty sure this can be retrofitted for a large fee if you really want it eddie (pretty sure it was an additional camera).
When I was reading about the speed display it was an old thread and it was possible by using a kufatec dongle to make the coding changes and someone was trying to work out what bits it actually changed to get it be able tk do it without the dongle. If it is not already cracked it is only just a matter of time.
Eddie555
Post by Eddie555 » Sat Dec 12, 2015 11:45 pm
MikeFish wrote:The cost of night vision would suggest it is a hardware addition but pretty sure this can be retrofitted for a large fee if you really want it eddie (pretty sure it was an additional camera).
I wasn't asking cause I wanted one. I was just curious to know after reading that piece of that thread that certain things could be switched on via VCDS. I for sure know things don't come for free that easy. Lol.
Current ride’s
Previous rides
Post by MikeFish » Sat Dec 12, 2015 11:47 pm
I often wondered how many cameras a fully specced RS6 has. Does anyone know the answer?
Users browsing this forum: RMP18 and 71 guests
