Mapping help
Mapping help
Hi all, I am a newbie here so please forgive me but I couldn't find what I wanted. I am imminently to become the proud owner of a B7 2006 RS4 Avant. That car is absolutely gorgeous, 79k miles with a service book full of stamps from Audi. My question is, living in the north west of England ( Preston ) are there any very good mappers you guys can recommend for me? I don't mind travelling if it means getting the right person with the right experience and knowledge of these cars?
Thank you.
Chris.
Thank you.
Chris.
Re: Mapping help
MRC are probably at the top of the list but there are a few others AMD are also pretty good from what i hear.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
Re: Mapping help
No particular order run all these tunes
Mrc
Viper tuning
United motorsports
Mrc
Viper tuning
United motorsports
Rs4 phantom black b7 avant : Mrc tuned
Re: Mapping help
Amd? Really? I've not read many good reports on here. Mrc are without a shadow of a doubt the berries and worth the run down. I used to travel from Glasgow to use them
Re: Mapping help
Tbh I haven't used them but a friend of mine has with his RS and was very happy.S4Player wrote:Amd? Really? I've not read many good reports on here. Mrc are without a shadow of a doubt the berries and worth the run down. I used to travel from Glasgow to use them
Like you said & probably 10/10 will agree MRC are no1
RS4 B7
Mapping help
Another vote for MRC, see my carbon clean thread!
AMD fitted the coilovers on my car and clutch (before I owned it.) They left the coilovers on different damper settings all round, and didn't properly torque up subframe bolts. In the past I had a milltek exhaust fitted by them on a golf Gti, badly...would touch the underbody of the car once warm. Ended up driving up to the milltek factory where they sorted it.
2007 RS4 B7 Avant
- PetrolDave
Re: Mapping help
Another vote for MRC.
After they fitted a Milltek exhaust and did a Stage 2 map (worth watching your car on the rollers while they tune the map) I went from smiling a lot while driving my RS4 to smiling insanely most of the time while driving it
Re: Mapping help
another vote for MRC and I had an AMD map before getting MRC to work their magic. the difference is night and day.
Re: Mapping help
I've had a terrible experience with AMD, I'll sum it up like this, they rushed putting my car back together and loads of stuff was loose, told me my turbos both needed changing (they're fine), the map they put on the car was a really really sh*t generic map (boost up and down like a yoyo, really poor low end power). Oh, they changed my cambelt and serpentine belts too, but didn't change the tentioner which failed shortly after and MRC put it right.
MRC are a bit on the expensive side, but their work is top notch, both physical workmanship and mapping. For basic servicing, brakes etc I do it all myself because I'm a bit OCD, for everything else I only go to MRC.
That said, Unit 20 also has a very good rep and is a lot closer to you.
Re: Mapping help
Thanks very much everyone. It seems MRC is the one.
Re: Mapping help
Plus 1 on mrc, ill be booking the rs4 in hopfully some time soon
Re: Mapping help
Yep MRC for remap.
Re: Mapping help
I was thinking about going for a remap myself so good to read where we should be going, MRC.
Can you notice a big difference after a remap and can the standard clutch handle it ok?
RS4 B7 Saloon Sprint Blue, Bilstein B14 Coilovers, Milltek Cat Back resonated non valved. Spacers 8mm F and 10mm R. Headlight clear zenon lens upgrade with 5500k bulbs plus indicator orange lens delete.
Re: Mapping help
Huge difference atfer remap. Not a big power gain though (NA engine already highly tuned)
I think you get maximum torque in first 3 gears, but the real difference is the throttle response in sport mode. It probably makes is no faster, or any more powerfull but it sure is a lot more fun. Feels like you have fitted a turbo and as soon as you touch the throttle it is on boost. Smiletastic.
Re: Mapping help
Thanks Mike,
Sounds great. So the standard clutch is up for the job?
At the moment my car has a resonated catback non valved Milltek with standard map, no other performance mods. When I drive the car I can't notice any difference when I push the sport button, doesn't seem to make any difference. Should I be noticing difference?
