The rear I heated up and took off, then used a caramel wheel to take the old sticky pads off and fix the new one in place
Pictures of my RS6 that I picked up on Friday
Re: Pictures of my RS6 that I picked up on Friday
hi I shall dig out the ebay seller. Front grill you need to be careful the badge is quite tight but once you get behind one tab it pulls off. The badge actually fits onto a secondary base which can also come off..if this happens this clips onto a base behind the grill, so just pop the bonnet up take off the plastic pop rivets that cover the rad and put your hand behind the grill so you can apply pressure from the back when you clip it back it.
Front grill badge size
http://www.ebay.co.uk/itm/Aftermarket-B ... Sw14xWPIQB
285X 99 mm
he also sells the rear badge I ordered both from him arrived in 2 days
285X 99 mm
superlightr
Thank you for your help.kavbhamra wrote:hi I shall dig out the ebay seller. Front grill you need to be careful the badge is quite tight but once you get behind one tab it pulls off. The badge actually fits onto a secondary base which can also come off..if this happens this clips onto a base behind the grill, so just pop the bonnet up take off the plastic pop rivets that cover the rad and put your hand behind the grill so you can apply pressure from the back when you clip it back it.
Hey kav. Long time, I was a member on evotechnik forum and you did some amazing work with the x5 and x6 you had
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
hey Andy small world
yes I sold the x6 and then purchased a F10 M5 kept that for 2 years but needed an estate car for the dog....looked at the X5m but didn't do anything for me, the F11 D5 Alpina estate are super hard to find so the RS6 was purchased
I'm pleasantly surprised with the car....actually TBH I luv it!
superlightr
ordered the front but couldnt see the rear.superlightr wrote:Thank you for your help.kavbhamra wrote:hi I shall dig out the ebay seller. Front grill you need to be careful the badge is quite tight but once you get behind one tab it pulls off. The badge actually fits onto a secondary base which can also come off..if this happens this clips onto a base behind the grill, so just pop the bonnet up take off the plastic pop rivets that cover the rad and put your hand behind the grill so you can apply pressure from the back when you clip it back it.
Do you know the size for the rear rings please? thx again
hi here is the rear one its about 1mm to big so you need to ensure you get all the glue off the bootlid before you fit this one
http://www.ebay.co.uk/itm/321906054816? ... EBIDX%3AIT
footsoldier
- 1st Gear
I ordered from here, you can choose C7 RS6 on drop down menu.
Look like they''ll fit, but I'm still waiting for car!
http://www.raywelldesign.com/shop/set-g ... di-badges/
Beautiful buddy proper motor good choice
Users browsing this forum: Google Adsense [Bot], Mcw543 and 95 guests
