ESP Light on getting these codes ....
Dabber
Post by Dabber » Sun Dec 06, 2015 1:40 pm
00257 ABS Inlet Valve - Left Front -N101
00259 ABS Inlet Valve - Right Front - N99
During driving today ESP light came on an stays on constantly read codes and are above any ideas ?
Please tell me it's not the pump/control module :(
R1RS4
Re: ESP Light on getting these codes ....
Post by R1RS4 » Sun Dec 06, 2015 2:47 pm
Hi there,
Just a few things to try
I assume you have copied then cleared dct's and tried again?
2, check for loose battery connections, can throw up these faults
3, check ABS module plug pins for corrosion, because it positioned next to the screen wash header, over a period of time the rubber seal can become perished due to over full of screen wash (glycol content)
Make sure the ignition is off before disconnecting !
4, if you clean any pins be careful not to bend any, spray with a good contact cleaner
Good luck
RS4 B7 Avant,2007
Dabber
Post by Dabber » Sun Dec 06, 2015 3:56 pm
Hi
Thanks for your reply, I have cleared codes after a few minutes of driving one of the codes came back but not both. I've looked at battery terminals and they look perfect not loose at all. The module doesn't look corroded tbh so I'm not sure :(
R1RS4
Post by R1RS4 » Sun Dec 06, 2015 4:25 pm
Look on the Ross-tech site
You will find a test procedure for testing the Abs module and components
R
RS4 B7 Avant,2007
R1RS4
Post by R1RS4 » Sun Dec 06, 2015 4:39 pm
Whose code reader are you using?
RS4 B7 Avant,2007
Dabber
Post by Dabber » Sun Dec 06, 2015 5:55 pm
It's a VS450 when you do an ABS scan nothing comes up.
Again thank you for your help so far.
R1RS4
Post by R1RS4 » Sun Dec 06, 2015 8:12 pm
No don't think you would with a basic OBD reader, you need to obtain the use of vcd's to run a scan
Where about are you?
RS4 B7 Avant,2007
Dabber
Post by Dabber » Sun Dec 06, 2015 10:36 pm
Broadstairs in Kent ;)
Dabber
Post by Dabber » Fri Dec 18, 2015 10:10 pm
As update, after diagnostic was the MAF read through these forums and realised the pipercross induction kit I bought second hand was still using the oiled filter, have now fitted the stage 3 dry version from revolution and changed MAF cleared codes and car is fine.
Would never had guessed as it seemed to be driving ok.
Thanks for your input, and thanks to revolution for giving me a forum discount ;) :bigwave:
