I know this has been discussed before but my searches did not really give me an answer - hense the post here
Fast Road/Trackday Brake Pads
What are the options other than EBC Greenstuff keeping brakes standard other than changing the pads to cope with the high temperatures generated by track use - standard audi pads are just not up to the job with their high wear rate and inability to cope with the heat build up.
tartan_rob
RE: Fast Road/Trackday Brake Pads
I have used Gren Stuff before, initially they are poo then for 3 or 4k miles they are great then they went worse than std. That was on a Fiat Uno Turbo 1.3 running 160bhp. My dad found exactly the same on His Saab Aero running 230bhp.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- wazza
- Top Gear
Not worth it IMO.
If you get pads that can be used at higher temperatures, then your brake fluid will boil easier.
If you change your brake fluid then the next weak link are the disks which warp under excessive use.
Been there, done that, and got the receipts to prove it (3 sets in a year
Either upgrade properly (AP/Movit/Porsche) or accept the standard brakes for what they are.
Paul
tartan_rob
To be honest, I have changed my oil for DoT 5.1 racing and gone for new discs and pads from Audi. The brakes are quite dull when cold or at low speed but at normal speeds 30mph+, I have had no problems at all, but I supose it depends on your tyres/suspension combination as well..?
PS BiTurbo - whereabouts are you in relation to magic roundabout?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- wazza
- Top Gear
Ahhh. The other Magic RoundaboutTartan_Rob wrote:PS BiTurbo - whereabouts are you in relation to magic roundabout?
Audi only sell one type.eatthis wrote:did u get standard pads and disks from audi??
I have tried both green and red from EBC, and also even had a set of standard audi disks machined to add the grooves in.
Paul
I am very happy with my current setup for fast road use - pagid fast road pads + DBA drilled & slotted + castrol SRF equivalent fluid.
If you are planning to do a number of track days, you should consider spending money on some proper brakes for the car, as it is a heavy beasty to slow down from high speeds.
tartan_rob
DBA disc are from Australia check out www.dba.com.au
Tony
S4- Possession without prescription is illegal
2000 S4 Silver, currently stock
Tony
