NewBee Q. - 2003 OEM Front Brake Disc Options
johnboy1973
Hi all
Hoping to join the ranks of RS6 Ownership in the next few weeks, after working through the Audi Avant ranks, having owned a early B5 2.5 TDI Quattro, then a B6 S4, and most recently a 2.5 TDi Quattro Sport.
The hot topic on these cars know is always the gearbox, and DRC, however one of the other thing I've seen is the price of the front disks, and I know they are very expensive, but the question I had was were there different options when new @ oem spec back in 2003. As in were all RS6's fitted with the drilled vented options, or what's there a solid option too?
I did have a good route around on the net to answer this, so if I missed it somewhere I apologise, don't flam me.
cheers in advance.
John
cheers in advance.
John
Re: NewBee Q. - 2003 OEM Front Brake Disc Options
John
Secondly, welcome along
Thirdly, I think you're telling lickle fibs about searching, there's about 1 million threads in this forum alone about brake discs!!!!
FON
The psychic RS6 hotline tells me there;s a brake thread right underneath this one.... With non-drilled fronts to be had for under £300 a pair
Recycling dinosaurs for fun
johnboy1973
Its all about the search words I guess lol.
Plus models had drilled as standard, normal had solid but drilled were an option.
johnboy1973
cheers that's the nugget that helps ;0)
PR-1LJ or PR-1LP I guess? ;0)
So having looked at the tread, another question I have is, why am I getting told by a RS4 B5 owner that you have to pay £1000+ for front brake discs? and there are no other options, just he just meaning if you want oem drilled discs from Audi you have to pay?
Do the drilled ones fail as much as I have read they car in real life?
cheers
John
cheers
John
B5 owners are living in the past.
You can get the drilled disks for barely more than the plain ones.
http://www.eurocarparts.com/brake-disc
Don't pay the advertised price though. Haggle and you should get them for about £160 each
RS6 C5, MTM
johnboy1973
Cheers guys, this is all good reading and better news on the purse strings.
Just to warn you, this will be one of the cheap repairs on a C5 RS6.
Have you had a good read through this forum? You'll learn A LOT and it may help decide if you can afford to run one of these. I'm not saying you can't, but it's nice to know before you jump in and then realize you can't.
Where are you based too, make sure you have someone local who knows about the cars to do any repairs.
And the final one, do you have a good sense of humour?
Or you could go here and pay £160 without having to haggleSteveo wrote:http://www.eurocarparts.com/brake-disc
https://www.123spareparts.co.uk/car-par ... Doc-100626
^^The fronts are 150. The rears are more expensive, bizarrely.
And if married do both your wife and bank manager have a good sense of humour?chunky79 wrote:Just to warn you, this will be one of the cheap repairs on a C5 RS6.
Why would Chunk's wife marry his bank manager?!
Can Chunky's Bank Manager supply and fit front discs ?
Users browsing this forum: Bing [Bot], philS2 and 1027 guests
