RS6 Plus transmission rebuild specialist in Midlands??
Re: RS6 Plus transmission rebuild specialist in Midlands??
yes for sure.
and they also use the auto transmission place that did the previous torque convertor rebuild last time.
Sounds like a better plan than an unknown place then.
If you were going north then I'd pop into Unit20 and see grizz. Or, as you're in the Midlands just pop down to MRC.
- jockthedog
I've been learning a lot about these boxes recently, including tearing one down to the ground and about to rebuild it.
Be very careful driving around with this issue.
If it's a valve-body problem (sounds like it) it could lead to the A drum coming in contact with the C drum and that would damage the A drum and other parts and require a complete rebuild. Apparently that is a common issue.
Don't want to worry you
As Chunky said
"If you were going north then I'd pop into Unit20 and see grizz. Or, as you're in the Midlands just pop down to MRC"
Hi
Where is best place to get transmission filter kit? I guess Audi would be best but are there any independant suppliers with same quality? Dont fancy ebay for obvious reasons.
Daytona Grey RS6 with Miltek stainless exhaust and Bilstein coilovers, magic tree air freshener.
Previous : Porsche 911 Carrera 4
Unit 20 recently did mine, I think they only use VAG parts.
Parts were about £70 Oil about £90, labour about the same as 1 hour at Audi.
Unless you have the knowledge, time and equipment to DIY, why would you?
For info original box 50,000 approx 25,000 since last change no problems or noticeable difference before or after change, but Grizz reported oil was 'burnt , slightly dirty but not metal on magnets. Basically needed changing for preventative maintenance.
I don't think it's worth the risk. There have been a lot of incidences of the wrong strainer being installed with nasty consequences (pick up pipe length differences).MarkPRS6 wrote:Hi
You're looking at list prices of about £45 for the strainer and £25 quid for the sump gasket. The oil is pricey, but check the FAQ for equivalent oils at other brand dealers.
Thanks for the input.
Well an update, my car has been at the garage for a couple of weeks now,
tried an oil and filter change first, made no difference.
next thing is an gearbox ecu swap, but they've been on back order, one arrived today.
If that doesn't work then its out with the box and engine...
btw is it really gearbox AND engine out job, or can it be removed without taking the engine out as well??
It is not impossible to remove just the gearbox. But there is almost as much work involved as removing both at once. There is also a much higher risk of damaging something.
Try Roger Bayliss transmissions in Cradley Heath
Very old school & knowleagble
01384 564844
07850399988
Tell him Dave Homer gave you his numbers he will sort you out
01384 564844
07850399988
Warranty Direct took my last RS6 to a place near Bedford and the did it without removing the engine. Was perfect after and I think they paid out about 2k. I was a few years ago though!
RS6 C5 05 plate very tidy.
Past.... Only have 500 characters ! RR Sport X 2 Nice but boring RS6 C5 03 Sold due to losing 25K of value in 12 months of ownership !
Still have a 72 GT6 and a few Big Bikes....
Central Axles Brum
Was it in St NEOTS by any chance??Cobalt wrote:Warranty Direct took my last RS6 to a place near Bedford and the did it without removing the engine. Was perfect after and I think they paid out about 2k. I was a few years ago though!
Users browsing this forum: philS2, Steve2003rs6 and 143 guests
