Enabling TPMS Again
psglas
Enabling TPMS Again
Post by psglas » Tue Sep 15, 2015 8:08 pm
I disabled my TPMS using VCDS a couple of years ago as I had no sensors on my winter tyres. It looks like the sensors are relatively inexpensive on ebay these days so I'm considering re-enabling it again as I'm not good at checking my pressures regularly. Before I purchase the sensors I just want to double check the control module is ok.
I'm currently seeing the following on a scan. Can anyone tell me if the module is ok ? Or can I run other tests ? Note: I still have TPMS disabled on Address 17/Channel 61.
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
VCID: 2A5127608608676E28-5140
1 Fault Found:
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 253
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 0.0
Temperature: 9.0∞C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
coffey555
Re: Enabling TPMS Again
Post by coffey555 » Sat Sep 19, 2015 7:31 am
As there is no aerial fault code you are probably ok.
I had the same fault codes before and after I changed out my controller module so likely all your sensors are flat.
Just add 512 to your current value I think once the sensors are fitted and you should be good to go.
Instruments Channel 61- 3331 TPMS Off
3843 TPMS On
Misano Red RS4 B7 Avant
psglas
Post by psglas » Sat Sep 19, 2015 10:17 am
Thanks. Will give that a shot.
Whereabouts in the car is the controller module btw?
coffey555
Post by coffey555 » Sat Sep 19, 2015 4:09 pm
The TPMS module is located on the passenger side behind the rear seat back above the wheel well. I had to take the whole of the interior panels off that side of the boot (on a Avant) to access it.
Not that hard to do but I would try the sensors first as much easier (for somebody else!) to change.
psglas
Post by psglas » Sat Sep 19, 2015 5:53 pm
Just curious. I've purchased some sensors from ebay. All being well that'll sort it.
sdp
Post by sdp » Mon Nov 02, 2015 8:43 am
Which sensors did you get. Are they working OK?
psglas
Post by psglas » Mon Nov 02, 2015 9:49 pm
Based on the info in this thread
viewtopic.php?f=35&t=115888&p=744647&hilit=tpms#p744647
I bought these sensors
http://www.ebay.co.uk/itm/4x-OEM-new-Au ... 1800929102?
I think they are the correct sensors but I can't get the car to sync with them. I switched on TPMS with VCDS but I just get a Low Pressure Red Warning on the DIS. I've tried letting air out and pumping up again with the ignition on. Then did a 30 min drive but still nothing. I drove around for a week with the warning but still can't get them synced. I did try the local Indy and tyre company but they don't have the wake up tool. The local stealer will charge to wake them up and they have been off for a couple of years so I can't be sure it's not the antenna or TMPS control unit.
Would appreciate any help if anyone has any ideas on how to sync them. I might try one more time to deflate/inflate.
Post by MikeFish » Tue Nov 03, 2015 12:55 am
Did you do a reset on the DIS? I think there is an option for new wheels.
psglas
Post by psglas » Tue Nov 03, 2015 8:09 pm
I can't access the DIS menu with the red low pressure warning showing. None of the steering wheel buttons are working unfortunately. I expect its fine with the amber warning but not the red one.
Post by MikeFish » Tue Nov 03, 2015 8:33 pm
I'm pretty sure they should still work with the red warning.
PetrolDave
Post by PetrolDave » Wed Nov 04, 2015 6:15 pm
psglas wrote:I can't access the DIS menu with the red low pressure warning showing. None of the steering wheel buttons are working unfortunately. I expect its fine with the amber warning but not the red one.
Have you tried with the ignition on but without the engine running?
psglas
Post by psglas » Wed Nov 04, 2015 8:33 pm
Pretty sure I did but will try again.
psglas
Post by psglas » Wed Nov 04, 2015 8:51 pm
Progress, left it 30 secs with the ignition on but without starting the engine and got into the wheel change menu. I've done a wheel change and reset the faults on VCDS channel 65. I can now see the IDs on the sensors zeroed out when I read the measurement blocks. Looks like it's ready to search of the sensors now. Hopefully if I take it for a drive they'll wake up and register. Cars stuck behind others in the drive so will need to wait until tomorrow for that.
Many thanks for the suggestion :-)
psglas
Post by psglas » Sat Nov 07, 2015 3:55 pm
Quick update. After I managed to do a wheel change on the DIS the sensors are now syncing up. All the sensor IDs and tyre pressure values are visible on the VCDS so I can confirm the sensors in the ebay link above definitely work.
PetrolDave
Post by PetrolDave » Sat Nov 07, 2015 6:49 pm
psglas wrote:Progress, left it 30 secs with the ignition on but without starting the engine and got into the wheel change menu.
I discovered that's how to get into the wheel change menu when you have a red TPMS warning a few years ago after I had new tyres fitted and the garage didn't have a clue how to clear the warning.
Users browsing this forum: Bing [Bot] and 386 guests
