Hi I'm new.
I have a rs6 c5 which is a animal, as most of you will know...
I have the solar roof and the windows mist up. Is there a way to stop this. ???
Rs6 c5
Re: Rs6 c5
There was apparently a late recall of sorts which stopped the fan coming on when the temperature was low I think. Mine does it too. Demists quickly though.
Check your scuttle panel for leaves/blockages though and make sure you haven't got any soggy footwells.
Daytona RS6 Avant
Re: Rs6 c5
Open the sunroof. you will then see 2 metal strips (1 each side), cover these with insulation tape. JOB DONE!
Re: Rs6 c5
Re: Rs6 c5
Whilst we are on the subject, my car has now started misting up inside quite badly (I however do not have a sunroof!).
If I use the heaters with air con off, it mists the windscreen up. Sometimes soon as I turn the heaters on the windscreen just instantly fogs.
I've tried an aircon bomb, that seemed to make it worse!! None of the carpets etc seem damp?
