Whooshing vacuum noise?
CycleSi
Post by CycleSi » Fri Oct 23, 2015 10:53 am
Since I have put the rear seats down in my B7 saloon to fit my bike in, I can hear a "whooshing" type noise like a vacuum or pump. I can't explain it very well, but it is coming from the back of the car and I haven't heard it before - only since the seats have been down.
Is it something to do with the suspension?
I'm more intrigued than concerned.
Thanks.
RichieRS
Re: Whooshing vacuum noise?
Post by RichieRS » Fri Oct 23, 2015 11:32 am
Something to do with the exhaust valves? (vacuum operated).
CycleSi
Post by CycleSi » Fri Oct 23, 2015 11:35 am
It happens constantly whilst driving.
If it were the exhaust valves I would have thought it would only be when l hit the Sport button and it would do it the once?
NJMAudiRS4
Post by NJMAudiRS4 » Fri Oct 23, 2015 11:54 am
Does it do it when stationary? If so then possibly a vac leak.
Does it do it only when moving ? If so then check the boot floor for any missing grommets as a possibility. Is it the fuel pump making the noise. Any damaged seals around Windows or boot area.
Hope it's some thing simple
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
Stazza80
Post by Stazza80 » Fri Oct 23, 2015 5:58 pm
Hi,
It might not be anything bad, on previous cars (r26 & m3) I had a similar noise with the seats down, actually sounded quite good. Amazing how much noise the seats hide from the boot area!
Ben
Dolphie
Post by Dolphie » Fri Oct 23, 2015 9:09 pm
Si,
The vacuum reservoir/solenoid valve is in the boot (I'm sure someone will correct me with the correct term). It's the blue thing that looks like 3 tennis ball spheres joined together.
I had the boot of my avant stripped out for some work and I could hear the type of noise you describe very clearly. I'm guessing the rear seats also help suppress the noise and that is why you are aware of it.
CycleSi
Post by CycleSi » Sat Oct 24, 2015 10:08 am
Yep; I think that is exactly it - the noise is to do with the vacuum system. With the seats back up it's silent again.
Thanks for all of your replies :bigwave:
Users browsing this forum: Google [Bot] and 123 guests
