Fitting a Road Angel into an S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
jonno1
Post by jonno1 » Fri May 20, 2005 4:03 pm
Has anyone hard-wired a Road Angel into their S4 rather than having to run ugly cables into the cigarette lighter?
If so, any idea how difficult/easy it is to do? The car is going to Dialynx next week - reckon they would be able to do it?
JonS
2000 Ming Blue Avant, Tanoga Short Shift, Revo, RS4 gearbox (not by choice), RS4 Wheels, Eibach Springs, Forge DVs = Happy Days
SimonS4MTM
RE: Fitting a Road Angel into an S4
Post by SimonS4MTM » Fri May 20, 2005 4:32 pm
Yes, easy job. Wire it into the fuze box located in the drivers side dash
jonno1
Post by jonno1 » Fri May 20, 2005 4:41 pm
The Road Angel comes with two cigarette lighter adapters - do I need to adapt these or buy a different connector which will plug into the fuse box - are you talking about the panel at the side accessible when you open the drivers door?
JonS
SimonS4MTM
Post by SimonS4MTM » Fri May 20, 2005 5:09 pm
Yes that is the panel.
Use the lead that is straight not curly. Cut off the cigarette lighter adaptor, then connected the two wires to a switched 12V and a ground (there is a well positioned screw near the fuse box for this.
Make sure you connect in the wright way round of course. I cannot remember which colour wire is +ve, but use a multimeter to check for continuity to the central connection on the connector that plugs to the road angel. This will be +ve
jonno1
Post by jonno1 » Fri May 20, 2005 5:14 pm
Thanks very much. Dont have a multimeter so may leave it to Dialynx!
JonS
jonno1
Post by jonno1 » Mon May 23, 2005 9:30 am
Did you have any problems with your Road Angel? Mine just says "Searching for Satellites" all the time and when it does occasionally find them, it drops the signal as soon as the car is moving pretty much. Does the S4 have a UV windscreen as I understand that this can cause a problem as the GPS signal cant get through and you need an additional antenna. Anyone had this experience?
Why is nothing ever easy!!!? :x
JonS
darrenstables
Post by darrenstables » Mon May 23, 2005 3:22 pm
my road angel 2 is working just fine. it is in the center of the dash right up to the windscreen and it is hard wired to the fuse box. i have had it for three months and it has worked fine all the time.
jonno1
Post by jonno1 » Mon May 23, 2005 3:33 pm
I am actually not certain the windscreen is standard. It has a slight tint and a pattern of black dots top and bottom.
JonS
BRETTCOLLINS
Post by BRETTCOLLINS » Tue May 24, 2005 5:43 pm
I have the original road angel, I works very in my S4.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
jacko788
Post by jacko788 » Tue Nov 22, 2005 9:40 pm
jonno1, just had mine back to blackspot for the same reason as you , verdict was the gps engine was faulty,they replaced it £35 inc del back to me .
Users browsing this forum: Google [Bot] and 27 guests
