light and strong Audi R8 V8
Re: light and strong Audi R8 V8
@Bam_Bam
Scales for weighing trucks consists of two scales.
Netto refers to the tractor, without trailers.
If you set the car on both scales, so you get the
Weight of the front axle and rear axle.
Tom
Tom
Wahoo!!!Speedr8 wrote:@Bam_Bam
Weight of the front axle and rear axle.![]()
Tom
- RossDagley
- Top Gear
accurate to +/- 10kgs?
Previously:
Previously:
Standard variance for a German moustache.RossDagley wrote:accurate to +/- 10kgs?
- RossDagley
- Top Gear
bam_bam wrote:Standard variance for a German moustache.RossDagley wrote:accurate to +/- 10kgs?
Previously:
Previously:
Hi
Here's a video with a back pressure measurement exhaust at 100-250 km / h.
Maximum exhaust pressure at 8000 U / min 110 mbar.
Measuring devices Capristo flap control with display in Navi up.
https://youtu.be/Ki4HyYQxX2Q
Tom
Tom
Errrm, what does this mean? Is this yet another way to measure horse power without a dyno or having to quarter mile it?
https://jeffdied.files.wordpress.com/20 ... ndom-1.jpg
I would like to share with you this picture of a fat dog saying "feeeeed meeeee".
That is all, thank you.
Hi
And here is the greatest sport air filter for the R8 V8 / V10 that can be mounted in the air box.
Compared to the old version + 20mm higher or 15% more filter area
Tom
Tom
Cool, so using your man maths this means you'll get more 15% more horsepower, right?Speedr8 wrote: Compared to the old version + 20mm higher or 15% more filter area
Hi
Unfortunately not, but the engine to can easier breathe air, my friend
Tom
Tom
- RossDagley
- Top Gear
What is the difference in pressure drop across the new filter Vs the old filter? I'd wager this is a complete waste of money personally but if it makes you happy...Speedr8 wrote:Hi
Unfortunately not, but the engine to can easier breathe air, my friend![]()
Tom
Previously:
Previously:
Tom, I'll buy a set from you ONLY if you can proof that they gain more horses compared to the BMC's that I have.
He's presented a rule1 right under your nose. They're bigger, = better, much better, best you can buy. Look at them them, they are bigger, but shorter and fatter. Probably the same surface area, but more expensive = better, waaaaay better, best you can buy.
