SamRs4 wrote:Thank mate will get on Oder a pair hopefully will be okTAB1S wrote:I would imagine even if they didnt it wouldnt take alot to get them to.
He's not on about buying miltek down pipes he's talking about these ebay ones on his milek catback.Grandadg90 wrote:Check this advert out. States only to be fitted to a Milltek system.
http://pages.ebay.com/link/?nav=item.vi ... 80&alt=web
So Sam this will not fit yours.
TAB1S wrote:He's not on about buying miltek down pipes he's talking about these ebay ones on his milek catback.Grandadg90 wrote:Check this advert out. States only to be fitted to a Milltek system.
If a miltek catback fits in the oem down pipes with out modification then his miltek will have to fit these ebay down pipes as they fit oem cat back? & im pretty sure there are small adjusters that the down pipes mount to so surely wont be far off?
Miltek are also bound to say only fit miltek to miltek.
Sorry, probably been mentioned a million times before but getting a little confused on the threads between pre-cat gutting (piggies?) resonator delete and x pipes etc etc.docurley wrote:I've just ordered a set with a set of these to stop the error codes.
http://pages.ebay.com/link/?nav=item.vi ... 64&alt=web
Thanks very much - unfortunately they are out of stock so have ordered the other ones instead. Should be okay but can always swap out later on if there are issues/don't fit I guess.docurley wrote:You will need the spacer but these may be a better one then the ones I bought and get round any spacer issues
http://pages.ebay.com/link/?nav=item.vi ... 79&alt=web
Mine also arrived yesterday! I also picked up new studs & nuts from tps as iv heard they almost always break when replaced!docurley wrote:Mine arrived on today and they look good, who knows till I drop her in the shop to be fitted if it's a straight swap but they do look well made.
Ozzyz wrote:They look good David, bet they'll make a nice difference when fitted!
I bought two spacers not four.TAB1S wrote:Mine also arrived yesterday! I also picked up new studs & nuts from tps as iv heard they almost always break when replaced!docurley wrote:Mine arrived on today and they look good, who knows till I drop her in the shop to be fitted if it's a straight swap but they do look well made.
When do you think you will be having yours fitted?? Mine wont be going on for a few weeks so very interested to see how you get on.
Also did you buy x4 lambda spacers?
Don't put spacers on the front lambdas, only the rears.TAB1S wrote: Also did you buy x4 lambda spacers?
JCviggen wrote:Don't put spacers on the front lambdas, only the rears.TAB1S wrote: Also did you buy x4 lambda spacers?
Users browsing this forum: Google [Bot] and 136 guests
