VCDS
ZacP
VCDS
Post by ZacP » Wed Sep 23, 2015 12:36 pm
Hi All,
Just chance to post this. Went to see Chris (Nobby) last night who kindly scanned my '6. Scanned once, then cleared and scanned again. Here are the results if you're interested. If you have any feedback, I'd be most grateful. Thanks again to Nobby for scanning and then taking the time to explain as much as i could understand to me!
Tuesday,22,September,2015,20:05:18:51144
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.1.0
Data version: 20150904
http://www.Ross-Tech.com
VIN: XXXXXXXXXXXXXXXXXXXXX License Plate: XXXXXX
Mileage: 70025 Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0004
Coding: 0010752
Shop #: WSC 02195 785 00200
VCID: 6BD537134942386698-5140
5 Faults Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit - Intermittent
17977 - Cruise Control Switch (E45)
P1569 - 008 - Implausible Signal - Intermittent
17473 - Fuel Pressure Regulation
P1065 - 008 - Regulation Discrepancy - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 02195
VCID: 6CD7340F1C4C3F5E91-5140
1 Fault Found:
17090 - Transmission Range Sensor (F125)
P0706 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 02195
VCID: 63C55F33F192702620-5104
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00001
Shop #: WSC 02195
VCID: 6ADB321716B8216EE3-2572
No fault code found.
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 P
Component: Airbag 8.4EP 3002
Coding: 0000606
VCID: 3D71C94B67B666D676-5140
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 02195
VCID: 3169E57BFBEE92B6E2-5140
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 B
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 01484
Shop #: WSC 00642
VCID: 275D0B23C52ADC063C-5122
WUAZZZ4B64N900667 AUZ7Z0C2442895
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 06859
Shop #: WSC 00739
VCID: 3467EC6F04FCA79E89-4EB0
8 Faults Found:
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0105
VCID: 2541012BBF26CE160E-4AE4
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02195
VCID: 26430627C220C50E07-5140
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 02195
VCID: 04077CAF14DCD71E79-4B16
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 00861
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H10 1006
Coding: 0000020
VCID: 285F081F9834D37E35-5140
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Part No: 4D0 907 273 C
Component: Reifendruckueberw. D310
Coding: 22350
Shop #: WSC 02195
VCID: 275D0B23C52ADC063C-5140
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 01156
Shop #: WSC 02195
VCID: 6DD1390B2756365686-5140
1 Fault Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
31-10 - Open or Short to Ground - Intermittent
End-------------------------(Elapsed Time: 05:13)--------------------------
Tuesday,22,September,2015,20:12:44:51144
Mileage: 70026 Repair Order:
75 76 77
Coding: 0010752
Readiness: 0110 1101
Coding: 00001
Shop #: WSC 02195
Coding: 06697
Shop #: WSC 02195
VCID: 63C55F33F192702620-5122
Coding: 00001
Shop #: WSC 02195
VCID: 6ADB321716B8216EE3-2578
Coding: 0000606
Coding: 01012
Shop #: WSC 02195
VCID: 3169E57BFBEE92B6E2-5122
Coding: 01484
Shop #: WSC 00642
Coding: 06859
Shop #: WSC 00739
VCID: 3467EC6F04FCA79E89-4ECC
Coding: 00102
Shop #: WSC 02195
VCID: 26430627C220C50E07-5122
Coding: 00050
Shop #: WSC 02195
VCID: 04077CAF14DCD71E79-4B30
Coding: 00017
Shop #: WSC 00861
Coding: 0000020
VCID: 285F081F9834D37E35-5122
Coding: 22350
Shop #: WSC 02195
Coding: 01156
Shop #: WSC 02195
VCID: 6DD1390B2756365686-5122
End-------------------------(Elapsed Time: 05:25)--------------------------
Nobby
Re: VCDS
Post by Nobby » Wed Sep 23, 2015 3:03 pm
Hi Zac. Good to see you last night. Initial thoughts on all the errors..... Its obviously worth scanning again soon to see if anything has re-appeared.
P1577 - 004 - Open Circuit – Intermittent
- Probably best to change the engine mount
P1569 - 008 - Implausible Signal – Intermittent
- New control switch needed
P1065 - 008 - Regulation Discrepancy – Intermittent
- Might be a problem with one of the fuel pressure regulators or could be down to the fuel pressure sensor(s). Might be worth checking a few things in VCDS and comparing values across both banks.
P1423 - 002 - Insufficient Flow – Intermittent
P1411 - 002 - Insufficient Flow – Intermittent
- Its probably the SAI pump not working. Check fuses and whether its actually kicking in when cold. If not fussed get it mapped out and blank off etc.
P0706 - 35-10 - Implausible Signal – Intermittent
- Both of these could be related to the F125 switch
35-00 - -
35-00 - -
35-00 - -
35-00 - -
- prett sure this is just the alarm telling you what has happened and not actually an error.
35-00 - -
- Haven’t got a clue what this means. Perhaps check the wiring diagrams for what ‘Terminal 15’ is.
59-10 - Can't Unlock – Intermittent
61-10 - Won't De-Safe – Intermittent
- New door lock probably needed.
76-10 - Terminal 30 missing – Intermittent
- Either the alarm is buggered or something has gone wrong with the batteries. Check the siren is working for starters and go from there. New sirens aren’t expensive or you could try to take the old one apart.
31-10 - Open or Short to Ground – Intermittent
- New sensor needed. Sure there are guides on here for replacing without having to remove the rear bumper.
Daytona RS6 Avant
Users browsing this forum: srichards and 94 guests
