Removing the front bumper.
Has anyone removed the front bumper from their car before? Exactly how simple(ha,ha) is it to remove the bumper on the S4? Any BTDT's.........?
RE: Removing the front bumper.
Dead simple,
1)Remove the undertray
2)Remove the 3 or 4 torx screws that hold the wheel liner to the bumper
3)Remove the 2 5mm hex bolts inside the wheel liner that hold the end of the bumper to the wheelarch
4)Remoce the 2 6mm hex bolts that are located through the front grills and attache the bumber support to the engine bay
5) Pull.
5) Pull.
Prawn
Prawn
"dead simple" - hmmmmm
I would change point 5 to:
Pull, swear, pull harder, collarpse into a gibbering heap. It's only when you reach the stage where
you think "F*** this, this bumper is coming off whether it breaks or not" is when you pull hard enough
to get it off. ymmv.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Glad I got the dealer to fix my headlight washer pump then. It may have set me back £200 but Jonny's description bears an uncanny resemblance to me in such situations.
2001 Silver S4 Avant
I would also change point 5 to Jonnys method, but add that if you press in at the front it levers the clips at the side allowing the rearmost part in the wheelarch to be released first. Do the same on both sides then it will come off (showering you in washer fluid as you have forgotton to unclip / block the lines)
It's an EVIL job, not due to it being technical, just fiddly.
Did I mention trying to line it up properly afterwards?
- SimonS4MTM
- Top Gear
I removed mine a few weeks ago, well nearly removed it, just enough so that i could re-attached the side of the bumper after the GF pulled it off.
Removed all the parts as described above appart from the washer lines. Was not too much of a problem.
Right. Its off. I can offer a bit more advice on step 5.
When the bolts are undone and the bumper is loose, if you look inside the wheelarch,riveted to the bumper is a moulded angle/ piece of short wheelarch. This actually bends slightly; just enough to see what the side of the bumper clips onto on the inner wing.
With this bent you can see were the bottom clip is in place.You can get a flat bladed screwdriver and lever this up, and as if by magic the top clips just pop out themselves
Refitting is a reversal of removal
Seriously, 20-30 minute job tops, no heavy handed tactics needed.
If its a foglamp there is no need to remove the bumper at all. The grill and suround piece where the fog light is pulls off. Grip the piece in the center and it just pulls off.
You can then see the foglamp bolted in place, although the bulb can be changed by unscrewing the holder at the back.......
HTH....
HTH....
Users browsing this forum: No registered users and 120 guests
