Rev Limiter in manual
4.2 V8 32v FSI - 444 bhp
Noyjatat
Re: Rev Limiter in manual
Post by Noyjatat » Sun Sep 06, 2015 11:24 am
465ps 484nm I had it done earlier this year it's probably still on the their Facebook gallery if you want to have a look at the graph buddy. I really like the gearbox map as the extra revs see you slightly up the rev range on each gear change. The multi stage launch control was good but I sometimes would over stage the pedal so we went back to a single stage and dropped the rev limit from the standard. It made it much better on the car yet still pulls well. Currently set at 4000 but gonna tweak it again to 4400. It had the stage 2 engine remap along with a carbon clean and has a custom exhaust (not including downpipes).
RIV
Post by RIV » Sun Sep 06, 2015 11:26 am
Is the gearing faster
Noyjatat
Post by Noyjatat » Sun Sep 06, 2015 11:35 am
I don't think the shifts are faster it just holds for an extra 250 revs or so which means that little bit more pull each gear. It's difficult to tell how much a difference that makes on its own as I had everything done as the same time. What I will say is that on its initial run the car made 401, after warming up some more it made 422, with the stage 2 it went to 430, then with the carbon clean and gearbox map finished at 465 (all PS figures)
S4WON
Post by S4WON » Sun Sep 06, 2015 11:35 am
Noyjatat wrote:465ps 484nm I had it done earlier this year it's probably still on the their Facebook gallery if you want to have a look at the graph buddy. I really like the gearbox map as the extra revs see you slightly up the rev range on each gear change. The multi stage launch control was good but I sometimes would over stage the pedal so we went back to a single stage and dropped the rev limit from the standard. It made it much better on the car yet still pulls well. Currently set at 4000 but gonna tweak it again to 4400. It had the stage 2 engine remap along with a carbon clean and has a custom exhaust (not including downpipes).
Very useful, thanks mate
Noyjatat
Post by Noyjatat » Sun Sep 06, 2015 11:37 am
May be doing the cats soon and tempted to decat to see what difference that makes. Will have to get valves fitted again if I go down that route though.
Post by HYFR » Sun Sep 06, 2015 1:18 pm
kmpowell wrote:
Eddie555 wrote:You can't bounce it in my C7. It hits the limiter and if you're not quick to change up the power completely dies and all the turbo power drops off.
That's because the C7 uses a single clutch ZF slush-box, not a double-clutch S-Tronic/DSG.
Back to the topic, I still don't understand why anybody would want to bounce their revs off the limiter through a corner. It's lazy, and quite frankly poor driving! Gear change to a suitable gear for the corner then feather the throttle accordingly.
It's not a single clutch
It's a slushbox as you said
The ZF will bounce on the limiter, even in my piss and slippers V6 oil burner
Anyway I think we are digressing, no one wants to bounce off the limiter, but the point of it is that Manual mode means full control. That I like.
RS6chris!
Post by RS6chris! » Sun Sep 06, 2015 5:48 pm
Noyjatat wrote:I don't think the shifts are faster it just holds for an extra 250 revs or so which means that little bit more pull each gear. It's difficult to tell how much a difference that makes on its own as I had everything done as the same time. What I will say is that on its initial run the car made 401, after warming up some more it made 422, with the stage 2 it went to 430, then with the carbon clean and gearbox map finished at 465 (all PS figures)
400 standard?.....pretty piss poor?
Same "exaggerated" power figures as a B7?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Graeme4130
Post by Graeme4130 » Sun Sep 06, 2015 5:52 pm
My first b8 made exactly 444ps at 8k miles, and my current made 424, but guy at RR said to expect 20ps loss due to winter tyres sticking to rollers
RIV
Post by RIV » Sun Sep 06, 2015 6:14 pm
Mine came out low, however it was one run, Doug said it can take up to 10 runs to get the figures up
However it's the same engine as the b7 with just a small difference in breathing, so why would it be a different story?
Users browsing this forum: No registered users and 170 guests
