Rnse startup volume
JmRS4
Rnse startup volume
Post by JmRS4 » Mon Aug 31, 2015 7:37 pm
Evening all. I've been having the issue with the startup volume on my rnse head unit in the rs4. I've done lots of looking on google but the posts done seem to have a solution. Has anyone found a solution to adjust it? Thanks.
audi_do_dat_den
Re: Rnse startup volume
Post by audi_do_dat_den » Tue Sep 01, 2015 5:39 am
I have been looking for exactly the same solution myself.... in a perfect world, it would be ideal to start up with the first few bars of ACDC's Back in Black.... at a moderately high volume....
HPsauce
Post by HPsauce » Tue Sep 01, 2015 8:53 am
So what exactly is the problem?
I thought all the RNS systems had menu options to control what the volume was at startup, e.g. a set level or as turned off?
audi_do_dat_den
Post by audi_do_dat_den » Tue Sep 01, 2015 10:15 am
No, sadly, the RNS-E doesnt have a simple 'power on' volume adjustment.
If its adjustable, its in the firmware of the unit itself and not open to adjustment by us mere mortals. Bit of a pain really.
Theres always the risk of the radio coming on with some Celine Dion, Robbie Williams or worse before you have time to hit the volume control.... :x
coldo
Post by coldo » Tue Sep 01, 2015 10:32 am
Are you sure? I can't remember exactly (not with my car at the moment) but im sure if you go into the sound settings, you can set both the Nav. volume and the default audio volume? Or am I dreaming? I must check later...
B7 RS4 Saloon - Sprint Blue
Surrey Sam
Post by Surrey Sam » Tue Sep 01, 2015 10:36 am
Coldo - you're not dreaming as you can change certain volume parameters within the menu. Startup volume is not one of them though.
In the RNS-e engineering mode there is Radio Test Menu 3 where you can set a volume figure for start-up. The only trouble is some RNS-e units accept/save the change and some don't. All three of mine don't, but I've read that some people get lucky and it's worked.
coldo
Post by coldo » Tue Sep 01, 2015 2:40 pm
Surrey Sam wrote:Coldo - you're not dreaming as you can change certain volume parameters within the menu. Startup volume is not one of them though.
Ah yes, correct. I've since checked and all I can change is the Nav Guidance volume and the Traffic Report volume. Ohwell.
PetrolDave
Post by PetrolDave » Tue Sep 01, 2015 5:29 pm
Surrey Sam wrote:In the RNS-e engineering mode there is Radio Test Menu 3 where you can set a volume figure for start-up. The only trouble is some RNS-e units accept/save the change and some don't. All three of mine don't, but I've read that some people get lucky and it's worked.
+1
I've had 2 RNS-E units (one pre-2010 and one 2010+) and it's worked on both for me - but in my alter ego as a Moderator on audiforum.us I've seen a "success rate" of maybe 50% at best for this to work - and there is no common setups, options, SW versions, etc.
So it's just pot luck...
JmRS4
Post by JmRS4 » Tue Sep 01, 2015 8:32 pm
Thanks for your replies. Is there a simple way of getting into the rnse engineering mode?
mikep99
Post by mikep99 » Tue Sep 01, 2015 8:35 pm
cut n pasted from http://mr-fix.info/audi-rns-e-hidden-me ... ring-mode/
RNS-E hidden menu access procedure
Turn the key to II position and wait for the RNS-E system to start.
Press and hold VOLUME/POWER knob to turn off the system.
Turn on the system again.
Press NAV button.
Press and hold upper-left soft button for 5 seconds.
Press and hold upper-right soft button. After few seconds RNS-E hidden menu will appear.
Release the button.
Although other sites advise holding the upper left button for 10 seconds...
JmRS4
Post by JmRS4 » Tue Sep 01, 2015 8:53 pm
Thanks very much. Will give this a shot in the morning. Seems daft not to give some simple adjustment on the headunit. Wouldn't mind but it's loud when it comes on.
JmRS4
Post by JmRS4 » Wed Sep 02, 2015 3:52 pm
Managed to get into the hidden menu. Which setting do I adjust? Thanks
JmRS4
Post by JmRS4 » Wed Sep 02, 2015 5:03 pm
I've got into radio test menu 3 and start up volume isn't in there.
Surrey Sam
Post by Surrey Sam » Wed Sep 02, 2015 5:35 pm
It's the bottom one in that menu.
rob-s
Post by rob-s » Thu Sep 03, 2015 5:54 am
I wonder if the BT telephone default volume could be adjusted? Mine is very loud at first call.
Daytona Grey B8.5 & Guards Red 981 / Ex.Audi RS4 B7 Sedan, Daytona Grey.
Users browsing this forum: vailpilgrim and 82 guests
