Tyre Pressure Sensors
RS6Rottweiler
Post by RS6Rottweiler » Sat Aug 29, 2015 11:03 pm
I have recently had the alloys on my RS6 refurbished and decided to replace all 4 tyre pressure sensors. Not thinking anything off it after they were fitted I had a puncture and noticed that the sensor did not activate. I have checked the owners manual but this says you go into the computer using the knob on the ecntre console but this does noy even pick up that they are installed. When I had the tyres replaced I chjecked that they were actiually fitted so I am looking fr any information that I can get as to how I activate the sensors after being replaced and get the car to recognise they are there? I appreciate that this might have been asked many times before but I cannot see anything in the forum that helps me so sorry if I am asking the obvious?
lala
Re: Tyre Pressure Sensors
Post by lala » Sun Aug 30, 2015 12:08 am
If you have Vagcom, you can read the info from the sensors ( tyre pressure, ambient temp, battery life remaining, position and a few more ). I did mine recently and had no issues. I ordered from Alloy Wheels Direct and got HUF BERU RDE001 TPMS tyre pressure sensor.
What sort of sensors are you using?
2004 RS6 C5 Avant
RS6Rottweiler
Post by RS6Rottweiler » Sun Aug 30, 2015 12:15 am
I bought the Audi sensor from Star Performance, very expensive so wont be happy if they are not working? However, the problem I have is they were given to the people refurbing my alloys so not sure if they have been installed correctly so will need to get the Jim or Brian to check it on Vagcom to confirm they are working and that they fitted the batteries?
Post by Shoppinit » Sun Aug 30, 2015 7:55 am
Sounds like they were previously coded out with the Vagcom. Probably the DPO didn't want to replace them and got fed up with the warning coming up on the dash.
To confirm, follow the procedure to learn the tyre pressures. If the option is missing from the menu then they've been coded out.
Post by bam_bam » Mon Aug 31, 2015 11:28 am
lala wrote:If you have vagcom, you can read the info from the sensors ( tyre pressure, ambient temp, battery life remaining, position and a few more ).
I did not know that!
Users browsing this forum: No registered users and 171 guests
