What Tyres?
3.0 V6 24v TFSI - 329 bhp
S4WON
Re: What Tyres?
Post by S4WON » Tue Aug 18, 2015 8:47 am
duggy72 wrote:
Fliptop wrote:Just to add to this thread. My S4 came with the OE Conti SportContact 5s in 255/35/19 when I bought it. I swapped the rear pair a while ago, for the same again, but the front pair were brand new in March so only recently have I needed to swap the fronts after about 10K.
I've gone for the Good year F1 Asym 2s as they are my favourite tyre from previous cars, and the difference versus the Contis is amazing.
I've not fallen in love with this car yet. Most things are great, but I have always found the steering to be horrendous. Heavy at speed, the car tramlined like a bastard, and just not confidence inspiring. My 15 year old Saab has better steering.
Well that was what I though, until I fitted the F1s. The car is absolutely transformed. I now can't wait for the rear Contis to wear out so I can have a matching set. Much lighter steering, none of the horrid tramline effect that made motorways a chore and any sort of fun a- or b-road with a bit of camber a nightmare. Now it can fly around the lanes of North Yorkshire like I always hoped it would.
What a difference, can't recommend enough that anyone using them should ditch those Contis asap.
I was under the impression that all 4 tyres needed to be changed at the same time? Even a small discrepancy in tread depth between front and rear could affect the quattro system.
I take it that this did not adversely affect your car?Image
There are plenty of threads on here about tyre depth/rolling diameter and the short answer is it doesn't matter (search my threads)
On different tyre and tread pattern though I wouldn't risk it. The usual advice is to change by axle, but with 4wd, haldex , DRC whatever, im not entirely sure that is good enough so woudnt take the risk
Im personally about to dump my 4 pzeros and go back to PSS, cant come soon enough, worse tyre ever but were on when I bought. Dumping 4mm left on rears
duggy72
Re: What Tyres?
Post by duggy72 » Tue Aug 18, 2015 3:04 pm
Thanks, I only ask as when I had an A6 allroad with torsen diff quattro the recommendation was to change all 4 as even a small difference in tread depth could affect the system.
Will have a read of your threads. Image
SuprSi
Re: What Tyres?
Post by SuprSi » Tue Aug 18, 2015 5:33 pm
Yeah that's bs, as long as they're all reasonable close tread wise and the same tyre there will be zero issues. All 3 diffs on this car are open, there's no limited slip diff to upset and the electronics won't be bothered by such a small variance as tread differences. And on an A6 allroad you're not exactly putting a lot of power to the floor so nothing to worry about.
Users browsing this forum: No registered users and 36 guests
