Spacers and tyre size
hector8
Post by hector8 » Tue Aug 04, 2015 8:14 pm
Hello for those running spacers on standard suspension could you tell me what size of spacers you run front and rear and tyre size please.
Fronts:
Spacer size -
Tyre size -
Rears:
Spacer size -
Tyre size -
I have emailed virdee also after reading a recent thread. Is this guy still trading??
I have an RS4 on the way and needs new tyres so probably the best time to order spacers too.
alefustec
Re: Spacers and tyre size
Post by alefustec » Tue Aug 04, 2015 8:55 pm
I'm running 10 mm front and rear. Perfect IMO but I know some run 8mm on front.
Increases curbing potentail but makes stance look so much better.
06 Phantom Black RS4 Saloon(since Jan 15)
19x9.5 Bola alloys, LED interior/door lights, exhaust flap delete, pre-cat delete, resonator delete, chrome to black optics, B&C pillars, rear boot strip, front grills & lower intakes gloss black, revolution induction kit, LED Drl's, de-tangoed, RNSE delete - Pioneer Apple CarPlay, reverse camera. 380mm upgraded JHM front rotors, Eibach control arms, Bilstein P14's, MCarbon diffuser & Cupra R splitter.
alefustec
Post by alefustec » Tue Aug 04, 2015 9:01 pm
hector8
Post by hector8 » Tue Aug 04, 2015 9:13 pm
Thanks for that. Definitely looks more aggressive
alefustec
Post by alefustec » Tue Aug 04, 2015 9:25 pm
Assuming it's got the OEM 19x9 alloys tyres are 255/35/19 if you change size you run into problems with speedo reading. Heard of some guys on Audizine running 275/30/19 but not recommended IMO.
FaisalJ
Post by FaisalJ » Tue Aug 04, 2015 10:37 pm
I bought spacers off virdee recently, try PM rather than email.
2007 RS4 B7 Avant
hector8
Post by hector8 » Mon Aug 10, 2015 8:50 pm
Have pm'd and emailed to no avail. Does anyone know him?
Post by MikeFish » Mon Aug 10, 2015 8:54 pm
hector8 wrote:Have pm'd and emailed to no avail. Does anyone know him?
You tried calling him? Pretty sure the number is in his signature.
Covkiller
Post by Covkiller » Mon Aug 10, 2015 10:11 pm
I'm running 20" S7 alloys with 4mm spacers, 235 30 20 Michelin Pilot Super Sport tyres. They are stretched but I rang Michelin beforehand and was informed that this would not effect handling or speed run safety.
Surrey Sam
Post by Surrey Sam » Mon Aug 10, 2015 10:47 pm
This properly shows the difference between OEM and a 10mm spacer. SS+ suspension will rub slightly with 10mm rear though, so best go 8mm front & rear.
CycleSi
Post by CycleSi » Tue Aug 11, 2015 10:26 am
I ordered mine from Virdee. I told him l had standard 19" wheels, standard size tyres and standard suspension - not the SS+ suspension and he said 8mm front and 10mm rear will be fine and the tyres WON'T rub.
And the rear tyres DO rub. When l contacted him he wouldn't swap the 10mm spacers for 8mm because they have been used. Of course they've been bloody used - I went with his advice after all. There aren't any DRC issues either.
I was surprised by his attitude and would suggest checking out other options before parting with your cash. It wouldn't have been too much to ask to have swapped them over !
Not a happy customer.....
slowcoach
Post by slowcoach » Tue Aug 11, 2015 10:44 am
what tyres are you running CycleSi ? i have Sport contact 3s with SS+ suspension and wanted to go with 10mm allround?
surprised you had been advised to stagger the spacer size as well ?
Audi RS4 B7 Saloon - Avus - SS+ Suspension - Tubi Exhausts (once i get round to fitting them...)
CycleSi
Post by CycleSi » Tue Aug 11, 2015 10:52 am
Brand new Goodyear Eagle F1 Assymetrics.
toyneg
Post by toyneg » Tue Aug 11, 2015 11:53 am
it's weird how people are experiencing rubbing with 10mm at the back as i run these and have no issues and my car has been lowered to the point where the top of the tyre pretty much sits just under the arch.
ASC
Post by ASC » Tue Aug 11, 2015 12:03 pm
Same, I'm low at the back with 10mm spacers and don't rub..
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
Users browsing this forum: Google [Bot] and 52 guests
