Some befores and afters from different angles
'Miles Better' evenMikeFish wrote:Much better!!
I only got the reference after clicking the photo which took me to your bucket!!steve_70 wrote:'Miles Better' evenMikeFish wrote:Much better!!![]()
Rears being done tomorrow if rain stays away
MikeFish wrote:I only got the reference after clicking the photo which took me to your bucket!!steve_70 wrote:'Miles Better' evenMikeFish wrote:Much better!!![]()
Came off no drama,no removal required with my method; I used a thin plastic trim remover tool to get under badge and a very thin blade screwdriver with some tape over the end to protect to lever on the clips.... be very careful not to lever on the outer black bezel or slip and scratch; so below is an alternative but will result in vandalism to snap lugs off to remove; depends if you want to have to go and buy a new badge if you need to go back to silver them at any point.RossDagley wrote:Pop in/out with no drama? B7 was a bumper off job iirc (well, the grill was for sure)
Here we go (RS4 badges on page 1).....http://www.raywelldesign.com/product-ca ... ges/page/2kmpowell wrote:Looks like they're good quality, how much, and where from?
Excellent thanks!steve_70 wrote:Came off no drama,no removal required with my method; I used a thin plastic trim remover tool to get under badge and a very thin blade screwdriver with some tape over the end to protect to lever on the clips.... be very careful not to lever on the outer black bezel or slip and scratch; so below is an alternative but will result in vandalism to snap lugs off to remove; depends if you want to have to go and buy a new badge if you need to go back to silver them at any point.RossDagley wrote:Pop in/out with no drama? B7 was a bumper off job iirc (well, the grill was for sure)
There was thread I saw somewhere where the clips had been accessed fron the rear and pressed down with screwdriver, I think he said it was fiddly and in the end he just snapped the lugs off from the back and lifted it off;
