Trickle charger?
Trickle charger?
Can anyone reccomend a decent trickle charger to use on the rs, i work offshore so am away for anywhere between 4-7 weeks at a time and need to find a decent trickle charger to put on it,
So many available i dont really know what to go for, been looking at the ctek mxs 5.0, any good?
Any help would be great
Re: Trickle charger?
The ctek you mention is really good, that's what I use if I'm away for a while.
I also bought a cigarette lighter adapter for it so there's no messing about in the boot
Ideal cheers si, need one by the weekend so uve sold me already haha
hi. on subject of chargers, i opened up the plastic cover under the bonnet with battery sign and could only see the '+' terminal.
can anyone please advise exactly how to get to the entire battery ...
thanks
thanks
No worries, it must be an awesome thing to get in the RS after being away for that long! Mine is my daily driver so I've got a bit desensitised to it.
Anawaz, it's in the boot where the spare wheel would be.
Haha yeah you could say that, first time i had driven in a total of 11 weeks was yesterday, deffinately missed it haha
Yes it's in the boot, but there is a negative connection under the cover too. This is useful if you reverse into your garage and need then a jump start later.SuprSi wrote:No worries, it must be an awesome thing to get in the RS after being away for that long! Mine is my daily driver so I've got a bit desensitised to it.
I use an optimate charger. Can't remember the model number off the top of my head though. You can buy a special lead for it that bolts on to your battery terminals and has a quick connection plug at the other end to allow you to connect to charger quickly and easily if use it often.
Ctek are the daddy!
I reverse into the garage and its tight, too tight. so can't open the boot. guess i could fold seats down, or explore under the bonnet options ?MikeFish wrote:Yes it's in the boot, but there is a negative connection under the cover too. This is useful if you reverse into your garage and need then a jump start later.SuprSi wrote:No worries, it must be an awesome thing to get in the RS after being away for that long! Mine is my daily driver so I've got a bit desensitised to it.
meanwhile here's link to ctek model as there's fair few to select from.
http://www.ebay.co.uk/itm/CTEK-MXS-3-8- ... 19ff91453d
cheers
No need to do that if you get a flat battery just pop the bonnet and connect up under the battery cover. The negative terminal is not as obvious, it's just a piece of metal, think it looks like a bit of pipe from memory (it's been a while though).
And have you never looked in your boot properly? Lol can't believe you haven't found the battery yet. There should be a tool box in there too as well as an electric tyre pump and some tyre sealant in case of a puncture.
oh. the piece of silvery coloured metal pipe pointing up in the air, when you look at it makes you think wtf is that lol
must be it.
cheers mate.
must be it.
cheers mate.
Yes that's it.anawaz wrote:No need to do that if you get a flat battery just pop the bonnet and connect up under the battery cover. The negative terminal is not as obvious, it's just a piece of metal, think it looks like a bit of pipe from memory (it's been a while though).
must be it.
cheers mate.
I leave mine for 6-8 weeks at a time and just leave the Ctek on it, no issues so far
Have had my c- tek for approx 8yrs now and car is sorn 6 months of the year and have had no problems.
Users browsing this forum: No registered users and 152 guests
