Exhausts!! It's time!! Which One :-)
Re: Exhausts!! It's time!! Which One :-)
It will be interesting to hear it Ross. The B8 in both stock form and aftermarket exhaust (Milltek) sound very different to the b7's and much louder. I'm not sure if it's to do with the dual air intake and cat / downpipes or not. The B8 Milltek seems to include a portion of downpipe, where the b7 was much shorter from cat back. Maybe this is the reason for the noticeable noise difference.
Interesting. I've never heard a B8 so assumed they sounded very similar.
I thought so too Mike until we put two together. Annoyingly the B8 does sound better... But the B7 still sounds epic. Will be interesting to see what custom fabricators of this caliber can do with it and therefore how it sounds compared to Neil's etc.
- RossDagley
- Top Gear
B8 underside photos from yesterday @ jcweldfab. Primary cats (HUGE) are stuffed up right inside below the manifolds.
Previously:
Previously:
disconnect the vavles, gut the pre-cats and chop out the centre resonator... Job done!
carsarecool
Who cares what it looks like??? How often do you get the chance to look at it?
It's called quality, why would you not care about what it looks like?
So anything under the car can look like it's been made buy a blind gimp!!!
But it doesn't matter cause you can't see it, really!!
This^.RIV wrote:It's called quality, why would you not care about what it looks like?
It's gonna sound immense.
Gone but never forgotten:
Astonished
Just checking as I may be having a brain fart momentRossDagley wrote:B8 underside photos from yesterday @ jcweldfab. Primary cats (HUGE) are stuffed up right inside below the manifolds.
Are we looking at an OEM exhaust or a new jcweldfab exhaust?
My guess is OEM as the process has only just begun, or did they work really fast at jcweldfab ....
carsarecool
Exactly.....you can't see it so what's the point??? Have you seen the OEM one??RIV wrote:It's called quality, why would you not care about what it looks like?
It's all about the sound for me....who gives f**k what you can't see.....well obviously you
Ross's photos were of the OEM exhaust on the B8.Astonished wrote:Just checking as I may be having a brain fart momentRossDagley wrote:B8 underside photos from yesterday @ jcweldfab. Primary cats (HUGE) are stuffed up right inside below the manifolds.
Neil posted some photos of the JC Weldfab exhaust on his B7.
- RossDagley
- Top Gear
im going to guess that in your youth you stuck filler and newspaper to cars, re sprayed it and called it "job done"? Doesn't matter about the build quality just the result.carsarecool wrote:Exactly.....you can't see it so what's the point??? Have you seen the OEM one??RIV wrote:It's called quality, why would you not care about what it looks like?
What it looks like is generally a good indication of the quality. And as you assumed I'd posted photos of a JCWF exhaust not a stock exhaust I'm going to assume you don't actually know a great deal of what you're talking about :p
Previously:
Previously:
carsarecool
Your "guess" is very wrong, I never got involved in car repair. I was simply amused with RIVs comments over build quality of something which can't be seen, that's all. I'll not get involved in such discussions with experts next time.RossDagley wrote:im going to guess that in your youth you stuck filler and newspaper to cars, re sprayed it and called it "job done"? Doesn't matter about the build quality just the result.carsarecool wrote:Exactly.....you can't see it so what's the point??? Have you seen the OEM one??RIV wrote:It's called quality, why would you not care about what it looks like?
just because it looks pretty does not mean it is.i payed £3k for the Armytrix the workman ship on the outside was out off this world till we put it on the dyno 120HP down with valves closed then i took a grinder to it and cut the thing open what a pile off <beep> inside
lesson one dont go off what it looks like
lesson 2 all about after sales service Armytrix did not want to know when there was a problem
All the more reason to go to a fabricator where you can see what they are doing
Users browsing this forum: No registered users and 177 guests
