ARB
ARB
anyone fitted after market Anti roll bars if so any noted improvement did it make the ride too harsh or make the suspension knock
as i'm looking to do this in the near future possibly lowering springs too but unsure about them at the moment
your comments are welcome
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: ARB
No one running after market anti roll bars ? H&R or others??
Re: ARB
With the sports diff I don't feel the need to look t or change this part like i did on my old B6 S4. THe sports diff seems to take care of all the understeer.
MY2015 Audi RS4 Avant quattro, Panther Black Crystal, Black leather, Black inlays, 20" V-Spoke wheels
MK2Golf24v
Re: ARB
The DRC does a decent job of controlling roll.
Re: ARB
Speak to Doug at MRC. They sell H&R bars for the B8 platform and I'm pretty sure he fitted them go his B8 S4, along with all the other Audi's he has / has had. He'll probably be able to give you an indication of what they'd be like on the B8 RS4.
Re: ARB
i hear what your saying about the DRC but i put H&R ARB on my B7 and it did tighten things up a bit it felt a bit more planted in the twisties so will probably go ahead with this mod a nd report back after afew week after its fitted
Astonished
Re: ARB
May be a dumb question but are there aftermarket ARB's and what are the claimed differences? Just larger diameter or also adjustable or?
Re: ARB
HRR also Eibach the H&R set is thicker also ajustible fronts nothing claimed on there sites
Astonished
Re: ARB
Thanks Brooner
Checked through and they seem to be 2mm larger diameter each end, which funnily enough seems to be the step up to the RS4 ARB which gets touted as the cure for lesser A4's.
The thicker ARB may help, as mine seems to be a bit unhinged/unsettled running "dynamic" on a rough country road in the wet, but is better on "comfort" in those conditions and may benefit from the thicker sway bar at the same time.
Now thinking ...
Now thinking ...
Re: ARB
theres a piont waht is the B8 RS4 ARB diamiters the H&Rs were 2mm thicker on the B& RS$ standard set up if there the sam as the standard B* no point in chnaging sway bar is somehting i hadnt thought about might call Doug and see what his thoughts are on the standard setb up and options
Re: ARB
Brooner wrote:theres a piont waht is the B8 RS4 ARB diamiters the H&Rs were 2mm thicker on the B& RS$ standard set up if there the sam as the standard B* no point in chnaging sway bar is somehting i hadnt thought about might call Doug and see what his thoughts are on the standard setb up and options
Re: ARB
yes got confused there i meant ajustible upper control arm
- Revolution
- Trader (Expired)
Re: ARB
Hi brooner
Out of the UK at the moment but please pm little glen and he will send you our options for roll bars
Glenn
Glenn
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Re: ARB
LOL, I meant your post made very little sense due to typos / autocorrections etc, and even then it just seemed like you'd dropped some random words in.Brooner wrote:yes got confused there i meant ajustible upper control arm
Re: ARB
MikeFish wrote:LOL, I meant your post made very little sense due to typos / autocorrections etc, and even then it just seemed like you'd dropped some random words in.Brooner wrote:yes got confused there i meant ajustible upper control arm
We jocks are incoherent at the best of time
