I have done 21k in my RS6. The car is a year old. It has started to vibrate/judder under heavy breaking from speed. I thought it was down to tyre wear and the need for new break pads. These were both changed a few days ago but it has not resolved the issue.
Just wondering if anyone else has had this issue? Is it normal and so should I live with it, or could there be another issue?
Brake Judder
Brake Judder
RS6 C7 Estoril Blue
Re: Brake Judder
I don't think that should be normal. I read a long term review here
http://www.carmagazine.co.uk/car-review ... st-review/
Look at Month 3 as they had brake judder after a while and Audi replaced the disks. Might be worth pushing back to Audi as a warranty issue
8L S3 with stage 2 (gone)
B7 A4 DTM (gone)
B7 RS4 (Miltek Res Valved, 100 cell cats, Ceramics, Carbon cleaned) gone
C7 RS6 Panther, carbon pack,
B7 A4 DTM (gone)
Re: Brake Judder
Having the same problem with mine! Wonder if they will sort it under warranty or put the brakes down as being consumable?
Let us know how you get on please.
Dave.
Dave.
danilobandeira
- 1st Gear
Re: Brake Judder
My rs6 with 160km started to do a louder noise when use the brake.
The audi dealer replaced the rotor and pad brakes for free in warranty
Re: Brake Judder
Worth giving this guy a call, he sorted my car at the weekend, knows his stuff that's for sure
http://www.discskimmers.com/5.html
100% recommended.
100% recommended.
RS4 Avant - Misano Red
Re: Brake Judder
I agree with the skimming, it fixed my recurrent judder issue, although at 21k miles I'd be looking at replacing the discs anyway. And new pads on an old disc won't help matters.
It could just be an uneven build up of pad material so you could try doing 7-8 hard almost-stops from 60mph, then drive for a bit too let them cool off.
Re: Brake Judder
I had this judder on my C6, after less than 7k KMs, was told to burn the residue off in the holds,
+1 for Suprsi's suggestion. I was told to belt down a big mountain and be firm on the brakes.
Re: Brake Judder
Booked into dealer 20th of this month? They say it could be a hub fault? Anyone else had this?
They also claim brakes are deemed as consumables & only warranteed the the 1st 600 miles! Surely cannot be the case if the discs are warped, that would mean a manufacturing fault?
Will update withe results.
Dave.
Dave.
