Top arms
N11LS_J
Re: Top arms
Post by N11LS_J » Fri May 22, 2015 12:54 pm
Guys
For those of you who have bought and fitted the adaptable UCA kit from awesome Gti (034), did you have any issues when fitting?
Apparently there is a 2mm gap where the pinch bolt goes through, and when tightened to torque the added stress has cracked the aluminium slightly :shock:
Instagram : n_i_l_s
Ozzyz
Re: Top arms
Post by Ozzyz » Fri May 22, 2015 1:55 pm
N11LS_J wrote:Guys
That is interesting, I'm considering going for these soon but if they have been known to crack when tightened that is not good! :thumbsdown:
N11LS_J
Re: Top arms
Post by N11LS_J » Sat May 23, 2015 12:47 pm
Ok, the arms aren't the problem, the torque setting are 40nm, and the kit does not state this, and apparently factory settings are 68nm, so when tightened to factory, the extra stress has cracked the aluminium on the upright slightly.
The 2mm gap is always present according to 034, even on the OEM arms, so don't worry about that.
Now I'm on the look out for a replacement upright :|
Instagram : n_i_l_s
Covkiller
Re: Top arms
Post by Covkiller » Sat May 23, 2015 7:16 pm
£300 from Audi as mine split too and a big job to change it. Strip the brake calliper, disk and hub assembly.
:nogarors4:
gt2
Re: Top arms
Post by gt2 » Sat May 23, 2015 7:18 pm
N11LS_J wrote:Ok, the arms aren't the problem, the torque setting are 40nm, and the kit does not state this, and apparently factory settings are 68nm, so when tightened to factory, the extra stress has cracked the aluminium on the upright slightly.
I had one of mine crack when fitting the kW adjustable kit. You're looking at about £350 for a new one
Covkiller
Re: Top arms
Post by Covkiller » Mon May 25, 2015 11:29 am
N11LS
Speak to this breaker, both sides could well have an in tact upright:
http://www.ebay.co.uk/itm/2007-AUDI-RS4 ... 259a01e1b9
andyg72
Re: Top arms
Post by andyg72 » Sat Jun 06, 2015 11:16 pm
A little update so I replaced the 2 upper front top arms pictured a couple pages back been on a few weeks drove to Germany a cheeky GP track blast and back home no issues drives smooth as it ever has done ..... Happy days
Users browsing this forum: Google [Bot] and 386 guests
