Making room for the 6
bobjebb
Post by bobjebb » Sat Jun 06, 2015 5:55 pm
On a lighter note...
If it ever turns up, I've cleared some 'winter' space - can anyone recommend a suitable floor covering to improve on concrete? I'm sure there's a liquid self-levelling material for this king of thing?
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
wildbore
Re: Making room for the 6
Post by wildbore » Sat Jun 06, 2015 6:28 pm
A few years ago I spent ages investigated treatments for my concrete garage floor - it looked just like yours does. I looked at several "flattening" and self-leveling compounds to give me a smoother surface. In the end, I established that, unless you want to raise the level of the floor noticably, none of them will work well - i.e. they won't bond properly in thin applications when you start driving cars over them (especially if you turn the wheel, which puts huge shear forces through the surface).
In the end, I just painted the floor with garage floor paint (after sealing it with garage floor sealer, which is essential). After I had finished, I realised that I had an 85% solution for a 10% investment.
There may be new, better flooring compounds around now that weren't then, or maybe an expert will provide better advice. But before you go too far down the self-leveling route, I would suggest that painting is mostly what is needed, and is well worth it.
bobjebb
Post by bobjebb » Sat Jun 06, 2015 7:18 pm
Good advice thanks. Not tiles then? Probably more expensive still...
Back with C6 RS6
And again C7 RS6
doodlebug
Post by doodlebug » Sat Jun 06, 2015 7:29 pm
Question. Why bother?
bobjebb
Post by bobjebb » Sat Jun 06, 2015 7:33 pm
Concrete is rough, dusty, flaky in places. Lots of other tools floating around dropping grass and mud etc, it's a pain to sweep clean with out a gas mask. Want something cleaner as a surface.
Back with C6 RS6
And again C7 RS6
doodlebug
Post by doodlebug » Sat Jun 06, 2015 8:51 pm
Gotcha. Thankfully my garage has not reached that point. Yet!
wrekka
Post by wrekka » Sat Jun 06, 2015 10:07 pm
Hi impact rubber tiles. Seen them in a lot of garages. Fit together like a jigsaw and you can drop hammers on them etc with no issues. Grizz at Unit 20 has some in his works garage. Easy to sweep too!
TTS RS4 -amazing machine,
Previous:
wildbore
Post by wildbore » Sat Jun 06, 2015 10:07 pm
bobjebb wrote:Concrete is rough, dusty, flaky in places. Lots of other tools floating around dropping grass and mud etc, it's a pain to sweep clean with out a gas mask. Want something cleaner as a surface.
Exactly like mine was.
Hose the floor down and brush it with a stiff broom.
Allow to dry thoroughly for a few days.
Apply Concrete sealer (from the same company that makes the floor paint).
Couple of coats of floor paint.
End of problem.
I painted mine about ten years ago and the finish is still completely intact.
Tiles: Yes, they are in my fantasy garage, and the Snap-on toolkit is sitting on those tiles, next to the Ferrari Dino.
Eddie555
Post by Eddie555 » Sat Jun 06, 2015 10:10 pm
I've carpeted mine and just use an old Hoover to vac it when required. But the garage only ever had my toy in there and my SNAP ON tools.
Current ride’s
Previous rides
R55ENS
Post by R55ENS » Sat Jun 06, 2015 11:43 pm
This is what you want for your floor:
Heavy duty rubber/plastic tiles. Cost about £450 to do a 3.5m x 5.5m garage! Looks great and is easy to keep clean!
RS4 B8 AVANT
bobjebb
Post by bobjebb » Sun Jun 07, 2015 1:09 am
Nice, trouble is, my floor is nowhere near level enough to lay tiles!
Back with C6 RS6
And again C7 RS6
wildbore
Post by wildbore » Sun Jun 07, 2015 7:55 am
R55ENS wrote: Image
Your floor is clearly designed to distract anyone who looks in your garage from the fact that you are hiding ET in there, though I think he is about to escape.
Users browsing this forum: No registered users and 125 guests
