Revs lift and hang while coasting....
craigsound
Re: Revs lift and hang while coasting....
Post by craigsound » Thu Apr 23, 2015 4:02 pm
I have something similar when slowly coasting and pressing the brake it revs high then settles down, is this something similar to the above mentioned ?
pixsaudisex2
Post by pixsaudisex2 » Thu Apr 23, 2015 5:18 pm
My car is doing this now... Urghhhhh,,,, Wonder what is best to do change the pcv... Seems like a pita to do.. Or is it throttle related.. :bash: :bash: :bash:
BaCoN
Post by BaCoN » Thu Apr 23, 2015 9:53 pm
Mine was doing the exact same thing ever since I did a carbon cleaned and it turned out to be a crack in one of the PCV hoses under the protective cover. Was only found using a smoke test for the vacuum leak and was fixed by simply heat shrinking over the top of it as the hose it pretty pricey from what i was told.
edge
Post by edge » Fri Apr 24, 2015 10:28 am
Yeah same issues as you guys are posting
BaCoN wrote:Mine was doing the exact same thing ever since I did a carbon cleaned and it turned out to be a crack in one of the PCV hoses under the protective cover. Was only found using a smoke test for the vacuum leak and was fixed by simply heat shrinking over the top of it as the hose it pretty pricey from what i was told.
THIS!
I got a new hose from Audi, but it was expensive for that it was.
pixsaudisex2
Post by pixsaudisex2 » Sat Apr 25, 2015 1:12 pm
Well yesterday i thought id have a go at changing the PVC for one i brought of ebay a few months ago from a s5...
Only when i got my old one in my hand did i notice the other one had the drain nipple missing.... Urghh new one from audi..
Fitted it this morning.. Had more of a pain getting it off than putting the new one back in but i also struggled like feck to line up my air filter after more than anything else..
But Hey quick test drive and KARR is back on track running sweeeeeeeettttttt.... :beerchug: :beerchug: :beerchug: :beerchug: :beerchug: :beerchug:
I will put a little write up later to show how to do it as i spent just as long looking for info on how to change it as doing the fecking job.. :beerchug:
O i borrowed my brothers VRS to pick up the parts 1.9 vrs diesel and well it shocked me a little bit what a nice car to drive.. ( all bit it never felt as solid at all as the rs4 but didnt really expect it to..
edge
Post by edge » Mon Apr 27, 2015 11:14 am
Fair play, one little item or leak can do so much to them!
Users browsing this forum: Squadr0n_ and 267 guests
