Bulging lower door trim
Re: Bulging lower door trim
Just open the door and look at the bottom corner near the hinge end and the bottom corner at the pillar end, two visible screws.
Ahh on the inside. I knew it was a stupid question. Many thanks.markwm wrote:Just open the door and look at the bottom corner near the hinge end and the bottom corner at the pillar end, two visible screws.
Good write up, must have a go at this mine are the same
Always good to have a go
I had a rear off side window trim that's bug me since Ive had the car,(18 months) always thought maybe the door had taken a knock and the door was misaligned, and it been in Audi about 5 times
I have tried pressing and moving the trim but no luck, so after washing the car the other day, I thought right doing that trim even if I have to take the door to pieces, went up to the trim with cloth pushed really hard and it clipped into place, nothing wrong with the door all looks good... Good job done by a <beep>!
RS4 B7 Avant,2007
So no need to remove the door card then?markwm wrote:Two screws on the inside of the door at either end, then it just slides out. Really easy.
No, they are below the door card. Two little black screws right at the bottom of the door at either end. You cant miss them with the door openDeano_123 wrote:So no need to remove the door card then?markwm wrote:Two screws on the inside of the door at either end, then it just slides out. Really easy.
Users browsing this forum: Google [Bot], Zyox and 171 guests
