Top arms
andyg72
Re: Top arms
Post by andyg72 » Tue Apr 14, 2015 8:27 pm
marc1 wrote:
andyg72 wrote:
MikeFish wrote:Sorry, they were £58 but now reduced further to £43 each.
http://www.eurocarparts.com/mobile/ecp/ ... 33a&000320
Oh bargain
I'd ring Jason at AllGermanParts too to see what he can offer you.
Cheers I will
gt2
Re: Top arms
Post by gt2 » Tue Apr 14, 2015 8:33 pm
I'm in the same boat as Mike as well. One side of my front camber is a degree out and I only have the kW springs fitted. I'll be buying a set of the adjustable arms in the near future.
Bladerider
Re: Top arms
Post by Bladerider » Fri Apr 17, 2015 1:26 am
I say go fully adjustable,
But then i guess Im biased lol
J.
RIV
Re: Top arms
Post by RIV » Fri Apr 17, 2015 7:03 am
I'm no expert but I don't understand why you would need them with coilovers and not lowering springs assuming the springs can lower as much as the coilovers.
A drop is a drop, lowering is what changes the camber, makes no difference if its just springs or coilovers
ChrisW
Re: Top arms
Post by ChrisW » Fri Apr 17, 2015 8:09 am
RIV wrote:A drop is a drop, lowering is what changes the camber, makes no difference if its just springs or coilovers
Yes, to a degree.
Different suspension setups like the mcpherson inherently increase camber with a drop, multi-link systems like the RS4 don't suffer from this. Before someone jumps down my throat, I'm simply regurgitating what Unit 20 told me when I questioned them about fitting adjustable top arms at the same time as the KW spring kit.
Peoples issues subsequent to lowering may be a combination of other things such as worn bushes, tracking etc etc. Im getting the tracking done on mine after everything has been fitted (new top arms, KW adjustable spring kit), so i'll be reducing the propensity for uneven wear quite substantially there.
Current: 07' B7 RS4 Avant
Previous: Mk2 Golf VR6 conversion, Mk2 Golf GTi 16v, Mk2 Golf 1.6 GL Auto, Mk3 Golf R32 conversion, BMW Z4 Coupe, BMW 430d, Audi S3, Defender 90 XS, Alfa Romeo 145
Harris.
Re: Top arms
Post by Harris. » Fri Apr 17, 2015 8:16 am
Once you lower a car everything changes , bushes take more strain and with the RS4 they suffer from top arm bushes so change them at the same time .
RIV
Re: Top arms
Post by RIV » Fri Apr 17, 2015 9:40 am
Don't agree at all I'm afraid, my b7 wanted for nothing, I replaced all the front arms, I also had a 4 wheel alignment every 6 months, as this goes out easily and needs checking regularly
My b8 was dropped at 10k no worn bushes, you need to be able to adjust the top arms to get the correct camber, it's impossible to do this with the oem setup, as lowering puts this out I would like to know how you get round this??
irn_bru_ce
Re: Top arms
Post by irn_bru_ce » Sun Apr 19, 2015 10:57 am
I was looking through old paperwork that came with my car, 4 top arms were fitted in 2011 at 37.4k miles
Part numbers were 8E4 407 505Q, 506Q, 509Q and 510Q, and they all cost £70.93 +VAT each
On the same receipt I also noticed the dealer used Mobil 1 for the service, I thought they used Castrol Edge?
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Re: Top arms
Post by MikeFish » Sun Apr 19, 2015 5:04 pm
+1
When I had my springs fitted, I had new shocks and new top arms fitted at the same time, and all by the experts at Unit 20.
Bladerider
Re: Top arms
Post by Bladerider » Sun Apr 19, 2015 6:45 pm
Yes, to a degree.
Nonsense !!!!
Im not jumping down your throat.
Nonsense is nonsense no matter who says it or how !!
ChrisW
Re: Top arms
Post by ChrisW » Sun Apr 19, 2015 9:48 pm
ffs. Why would they say I don't need them..?
RIV
Re: Top arms
Post by RIV » Sun Apr 19, 2015 10:16 pm
I was also told by another specialist I didn't need them, I'm afraid they got it wrong!!
andyg72
Re: Top arms
Post by andyg72 » Mon Apr 27, 2015 9:20 pm
Well I went out and brought a pair of top arms today I'm told oem quality with same warrenty but more than half the cost so I'll get theses fitted while in for its major service before my Germany trip to the ring in 3 weeks ;)
Harris.
Re: Top arms
Post by Harris. » Mon Apr 27, 2015 9:53 pm
Where did you get them from in the end ? what was the total price for both sides ?
andyg72
Re: Top arms
Post by andyg72 » Mon Apr 27, 2015 10:15 pm
Ces & £78 total
Made in Germany I'm happy with that
Users browsing this forum: No registered users and 339 guests
