Hello,
I want to thank you for you precious advice to solve my RS4 problems.
While I connected the VAG-COM I found these errors:
Charge pressure control: positive deviation
Bank 1: Fuel trim (Add) Too lean
Bank 2: Fuel trim (Add) Too lean
I checked th Bypass Velves (Dump Valves) and I've noticed that:
- One valve was broken (checked with MityVac suction pump).
- One hose from the other valve was unsecure and partially disconnected.
No warning lamp on the dash.
I've replaced the Dump Valves with 2 new Bosh 110 that should be equal to the Audi 710N:
http://www.hoppenmotorsport.com/bypass.htm
http://www.s4biturbo.com/art-dvtests2.php
The old valves were Audi 710A
http://www.s4biturbo.com/art-dvtests.php
Then I drove the car for about 50 Km then I reconnected the VAG-COM.
0 ERRORS FOUND!!!
So...Thank you very much for your precious advice!!!
Nicola
[THANKS] Was Charge pressure control: positive deviation
RE: [THANKS] Was Charge pressure control: positive deviation
Keep an eye on your MAF
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Users browsing this forum: No registered users and 39 guests
