Fed up with 20's! Advice
Surrey Sam
Re: Fed up with 20's! Advice
Post by Surrey Sam » Tue Nov 11, 2014 6:38 pm
I get light rubbing on the rear with SS+ suspension, no passengers, OEM wheels, 60% worn GY F1 and 10mm spacer. Only when B road bashing though but its enough for me to look at changing the rear spacer from 10mm to 8mm.
flying_tomatoes
Post by flying_tomatoes » Wed Nov 12, 2014 6:02 pm
If your only rubbing in the front remove the screw that's top dead center of your fender well. This solves the issue for alot of people.
You could also always tweak your alignment a bit and add .2* of camber all round. That would give you a bit more clearance and that little amount of camber wont affect the way the car feels hardly at all. Might not be ideal but its cheaper then getting new tires!
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
MartayMcFly
Post by MartayMcFly » Sat Nov 15, 2014 4:55 pm
I don't think the RS4 is camber adjustable at the front, it involves re-jigging the whole subframe.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
E14STO
Post by E14STO » Sat Nov 15, 2014 5:43 pm
Not sure about that. You would have thought you could tweak the RS. Mine runs KW 3's pretty low. Wouldn't that introduce some camber changes simply as a subsequence of lowering it??
It certainly wears slightly quicker on inside edges of both fronts...
I've replaced front standard tyres for the moment until I decide what to do.
Looking for some decent affordable 255 30 20.
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
gt2
Post by gt2 » Sat Nov 15, 2014 5:59 pm
You can buy adjustable top arms that adjust your camber. They are fixed as standard though. My camber is also out due to fitting lowering springs
Post by MikeFish » Sat Nov 15, 2014 10:31 pm
gt2 wrote:You can buy adjustable top arms that adjust your camber. They are fixed as standard though. My camber is also out due to fitting lowering springs
+1 you can adjust toe at the front but not camber unless you have adjustable arms.
flying_tomatoes
Post by flying_tomatoes » Mon Nov 17, 2014 2:33 pm
MartayMcFly wrote:I don't think the RS4 is camber adjustable at the front, it involves re-jigging the whole subframe.
You can absolutely adjust the camber, just not a whole lot with out adjustable arms. How do you think they take the camber out after you lower the car on coil overs?
MartayMcFly
Post by MartayMcFly » Mon Nov 17, 2014 2:37 pm
They don't, unless you fit adjustable control arms.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
flying_tomatoes
Post by flying_tomatoes » Mon Nov 17, 2014 2:41 pm
hmmm... maybe your right, come to think of it I fitted my adjustable arms at the same time as my suspension. I know for sure the rear is adjustable.
DavidRS4
Post by DavidRS4 » Thu Mar 19, 2015 8:45 pm
I have 20 x 10.5's all round. Got 265/30 tyres on. Had the front arch lip removed and am running KW V3's with adjust able top mounts. All is good here :)
N11LS_J
Post by N11LS_J » Fri Mar 20, 2015 12:14 am
DavidRS4 wrote:I have 20 x 10.5's all round. Got 265/30 tyres on. Had the front arch lip removed and am running KW V3's with adjust able top mounts. All is good here :)
Pics please!!! :biggrin3:
Instagram : n_i_l_s
Covkiller
Post by Covkiller » Fri Mar 20, 2015 7:13 am
I run:
20" x 9" S5 alloys
KW v3 63.5mm front 64.5mm rear (ground to top of wheel arch)
Adjustable top control arms
Previous:
255.30.20 rolled arches with 5mm spacers = front arch's rubbing all over the place
Now:
235.30.20 flattened & respreayed arche's with 4mm spacers = no rubbing so far
It's been a week with some keen driving too.
On these wheels I did try 3mm spacers but the clearance with the inner edge of the caliper is so tight you can just get a piece of paper to slide in. So when racing & expanding I'm sure the caliper would hit the wheel. So I went for the extra millimetre ie 4mm.
Here's some photographs:
It doesn't look as low as before even though I had it dropped another 5mm all round when the control arms were fitted. The Back KW's are on the lowest setting for their tolerance too.
r5ccu
Post by r5ccu » Fri Mar 20, 2015 7:45 am
I'm running 20x9 et 25 with 255/30 and kw clubsports only slightly rubbing from rear but mine is very lowImage
Sprint blue,kw clubsports,milltek non resonated,k&n,dectane rears,led drl,20x9 rohana rc10 et25 ebc yellowstuff pads f+r revo tune
DavidRS4
Post by DavidRS4 » Fri Mar 20, 2015 11:56 am
Teaser for now. Phone is pissing about with adverts on photobucket
N11LS_J
Post by N11LS_J » Fri Mar 20, 2015 1:26 pm
And no rubbing you say David??? :shock:
Even at that height?
Looks immense!
:bowdown: :thumbs:
Instagram : n_i_l_s
