Spacers
DuncS3
Spacers
Post by DuncS3 » Mon Mar 17, 2003 2:16 pm
Thinking about Spacers on my S3 - questions are:
1) Do they affect the handling of the car (widened track etc)
2) My car has standard suspension and most likely will stay that way for a good while - any caveats with spacers, like wheels rubbing on wheelarches etc?
3) Would spacers affect the life of components, ie drive, suspension etc? (are they safe)
Dunc [img]images/graemlins/s3addict.gif[/img]
Thorney
Location: Wherever the centre of the universe is, I'm about as far away from it as possible.
Re: Spacers
Post by Thorney » Wed Mar 19, 2003 12:39 pm
1). Yes they can do - helps to widen track.
2). Be careful you don't go too wide as you could hit the arch, bit of a suck it and see thing really. Normally 10-30mm is OK.
3). Bolt on spacers (where they actually bolt onto the wheel) are best as they simply make the wheel wider in effect - Sportec for example. Insert spacers aren't quite as good but the level of extra stress on bearing etc is dependant on how wide you want to go.
DuncS3
Re: Spacers
Post by DuncS3 » Thu Mar 20, 2003 4:58 pm
Bolt on Spacers - is that of the 'hub' variety ala Forge (and Sportec?)?
DuncS3
Re: Spacers
Post by DuncS3 » Thu Mar 20, 2003 4:59 pm
I only posted this in S3 to keep the section moving! I see there is a S4 one too - knew it should of been in tuning and technical!!!!!
PhilT
RS246.com
Re: Spacers
Post by PhilT » Thu Mar 20, 2003 5:21 pm
Right, I've moved both the posts to this section. You'll have to fight between you to see which one continues longest...
[img]images/graemlins/033102talk_1_prv.gif[/img] [img]images/graemlins/033102talk_1_prv.gif[/img]
Users browsing this forum: No registered users and 46 guests
