go pro advice
Off topic chat
geordie jay
go pro advice
Post by geordie jay » Thu Feb 26, 2015 12:07 am
got myself a go pro for xmas and tried it out last weekend..problem is when I try to download onto photobucket or even you tube it wont support it,.im not technically gifted so any advice in kid language would be grateful..i think it needs to be changed into jpeg or something like that :biggrin3:
cheers jay
MartayMcFly
Re: go pro advice
Post by MartayMcFly » Fri Feb 27, 2015 2:29 am
The main problem with GoPro is the compression they use is so high (slower computers can't even play the video back properly). To get the compression to a usable level, download the free GoPro Studio software and convert any files you want to use. I'm assuming you're going to just upload entire clips, rather than going through editing... would take a lot longer to talk you through. The software is pretty straight forward, but here's a step-by-step in case:
Download the software from here http://shop.gopro.com/EMEA/softwareanda ... tudio.html and install it
- Open the software, and click on Import New Files (blue banner on the left).
- Select the clip you want to upload
- Click 'Add Clip to Conversion List' (blue button bottom right of video)
- Click 'Advanced Settings' (grey button to bottom left of video) and make sure Quality is set to HIGH, hit OK
- Click 'Convert All' (blue button again, at the bottom) and wait for the Processing bar to reach 100% under the thumbnail in the Conversion List
- that bit can take a while, depending on the resolution, length and your PC
- Click 'Proceed to Step 2' where 'Convert All' was
- Cancel the pop-up template thing and click on 'Step 3 Export' at the top, that'll bring up a box
- Pick either 'YouTube' or 'HD1080p' (which will keep it slightly higher quality) and then EXPORT
- Select where you want it to save, and give the file a new (or leave it as the default).
- Wait for it to Export, and then upload that new file to YouTube
And .jpg (jpeg) is for pictures, not video... fyi
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
geordie jay
Re: go pro advice
Post by geordie jay » Fri Feb 27, 2015 6:33 pm
thanks martin,i will try it over weekend :thumbs:
geordie jay
Re: go pro advice
Post by geordie jay » Fri Feb 27, 2015 8:45 pm
decided to do it and sorted it onto you tube cheers mate
RossDagley
Re: go pro advice
Post by RossDagley » Sat Mar 21, 2015 10:57 am
If your gopro is wifi, then using the app on a phone is very straightforward too. Can have a clip on YouTube within minutes quite easily :) For stuff that doesn't need editing that's the easiest way forward imo.
Previously:
geordie jay
Re: go pro advice
Post by geordie jay » Sat Mar 21, 2015 6:18 pm
cheers ross :thumbs: I been having fun with it,,,i good piece of kit :bigblink:
Return to “Off Topic Chat”
