Airbag light drivers seat
Nickrs4.2
Post by Nickrs4.2 » Sat Feb 21, 2015 6:11 pm
I have the buckets seats and have the airbag light on. It's been plugged in and has a low resistance. Anyone else had the pleasure of dealing with such issue. Could I put a resistor in place?
Re: Airbag light drivers seat
Post by MikeFish » Sat Feb 21, 2015 8:48 pm
Have you tried resetting it to see if the fault comes back again or is it permantently on?
coffey555
Post by coffey555 » Sat Feb 21, 2015 11:51 pm
Nickrs4.2 wrote:I have the buckets seats and have the airbag light on. It's been plugged in and has a low resistance. Anyone else had the pleasure of dealing with such issue. Could I put a resistor in place?
Have you switched from comfort to bucket seats or has the light just came out of the blue?
Misano Red RS4 B7 Avant
DaytonaRs4
Post by DaytonaRs4 » Sun Feb 22, 2015 6:47 am
i have buckets as standard and get the light on now and then, i find its when the seat is put fully back for cleaning carpets etc then the light sometimes comes on, for me it must be the wire going to the plug stretching or something, it clears no problem with VCDS for me though, i have removed all plugs and checked connections and nothing looks loose.
2013 RS5 Phantom Black, MRC Stage 2 and TCU, Bilstein B16 IRC, 034 Arms, H&R ARB's, Milltek non res, ITG, 20” Ispiri FFR6 / PS4s, AP Radical 6 pot brakes / 390mm floaters, Pagid RSL1, JL Audio, EMtuning headlight build, Gtechniq ceramic and Llumar PPF
Gone: Daytona B7 RS4 saloon
Nickrs4.2
Post by Nickrs4.2 » Sun Feb 22, 2015 9:45 am
Car has always had buckets has been to Audi they have tried to reset but fault re appears when ignition goes back on. They believe there could be a fault with the airbag? That's why I was thinking of fitting resistor rather then having no working airbags.
coffey555
Post by coffey555 » Tue Feb 24, 2015 12:36 am
The buckets don't have side airbags like the comforts so it could be front or curtain airbags causing the fault. Surprised it is not showing a specific fault code showing which airbag or controller is faulty. Could also be a faulty resistor in the yellow plugs under the seats.
Might be worth unplugging them to see if any more fault codes are displayed?
leadfoot
Post by leadfoot » Tue Feb 24, 2015 2:28 pm
I have the same problem... and the light goes on and off on its own... sometimes i can get it to go off by brake or accelerating hard.... I have done a little bit of research, and it appears there is a connection under the seat that becomes loose and /or corroded... but I have not spend time trying to resolve my issues.
Users browsing this forum: Google Adsense [Bot] and 146 guests
