What MAF g/s airflow have you reached
Re: What MAF g/s airflow have you reached
It may help the tumble effect but I haven't noticed anything bad. I just see it as something in the way of the air flow I've had a 30 bhp increase from my exhaust and Inlet changes with the revolution filter. L9oked forward to mapping it
I've logged 191.19g/s in 2nd gear and 186.92g/s in 3rd
Time----------Engine----------Mass Air----------Throttle----------Ignition
Stamp--------Speed/min-----Flow g/s---------Valve Angle %----°BTDC
2nd Gear Run
380.44---------8000------------191.19--------------99.6--------------29.3
3rd Gear Run
473.77---------8080------------186.92--------------99.6--------------25.5
That’s approximately 478 hp and 467 hp. That can't be right can it?
2nd Gear Run
3rd Gear Run
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Do you not log in a higher gear?
No, what gear do I need to use?
Chargedrs4
Monday 21 July 2014 11:16:53:46638 VCDS Version: Release 12.12.2 (x64) Data version: 20140212
8E1 910 560 A 4.2L V8/4V FSI ª0060
Group A: '031 Group B: '021
'003
Engine Speed Mass Air Flow Throttle Valve Angle Ignition
(G28) (G70) Timing Angle
/min g/s % °BTDC
3560 18.81 23.1 43.5
3600 18.78 23.1 43.5
3600 18.75 23.1 43.5
3600 18.61 22.7 43.5
3640 19.92 24.3 43.5
3640 40 31 39.8
3960 145.5 94.9 15.8
4080 143.81 99.6 15.8
4360 153.17 99.6 14.3
4680 163.83 99.6 13.5
4880 171.97 99.6 13.5
5160 183.22 99.6 14.3
5400 193.42 99.6 14.3
5640 204.33 99.6 14.3
5880 215.67 99.6 15
6120 225.33 99.6 15
6320 236.22 99.6 15
6600 250.08 99.6 15
6760 255.33 96.9 15
6880 26.36 26.3 16.5
6400 26.33 26.7 10.5
5960 24.67 25.9 9.8
5480 30.31 27.5 6
5000 24.39 25.1 4.5
4520 20 23.1 1.5
4440 15.97 21.2 10.5
4480 15.94 21.2 12
4560 15.61 21.2 12
4560 15.69 21.6 12
4520 16.06 21.6 12
4480 15.56 21.2 12
4480 15.36 21.2 16.5
4440 15.47 21.2 21
4440 15.44 21.2 30
4440 14.97 20.8 40.5
4440 15.03 20.8 44.3
4440 14.92 20.8 44.3
4440 15.22 20.8 44.3
4400 15.11 20.8 44.3
4400 15.22 20.8 43.5
4400 15.19 20.8 43.5
3160 12.61 18 0
3120 12.42 18 0.8
3120 12.53 18 0.8
3120 12.17 17.6 0
3080 12.11 17.6 0
3040 12.22 17.6 0
3040 10.28 14.5 4.5
3040 10.08 14.9 17.3
3040 16.81 21.6 27
3120 43.92 30.2 24
3120 92.42 46.7 -3
3200 106.81 99.6 10.5
3320 110.86 99.6 11.3
3440 113.78 99.6 12
3600 119.56 99.6 12.8
3720 125.39 99.6 14.3
3840 131.19 99.6 15
4000 136.19 99.6 16.5
4120 141.78 99.6 16.5
4240 147.22 99.6 15.8
4360 152.03 99.6 15
4520 157.33 99.6 14.3
4640 163.22 99.6 14.3
4760 167.89 99.6 14.3
4840 172.72 99.6 14.3
5000 176.58 99.6 14.3
5120 181.67 99.6 14.3
5240 186.64 99.6 14.3
5360 192.31 99.6 14.3
5520 197.31 99.6 14.3
5600 202.08 99.6 14.3
5720 206.94 99.6 14.3
5840 212.81 99.6 15
5960 217.53 99.6 15
6080 222.86 99.6 15
6200 227.83 99.6 15
6320 232.67 99.6 15
6400 238.03 99.6 15
6520 243.69 99.6 15
6640 249.56 99.6 15
6720 254.19 99.6 15
6840 258.94 99.6 15
6920 258.81 99.6 15
7040 263.39 99.6 14.3
7120 268.22 99.6 14.3
7200 270.58 99.6 14.3
7280 275.69 99.6 14.3
7320 278.67 99.6 14.3
7400 282.67 99.6 14.3
7440 285.44 99.6 14.3
7560 288.42 99.6 14.3
7640 292.97 99.6 15
7680 296.39 99.6 15
pes whipple
'003
/min g/s % °BTDC
3640 40 31 39.8
5880 215.67 99.6 15
6120 225.33 99.6 15
6320 236.22 99.6 15
6600 250.08 99.6 15
6760 255.33 96.9 15
5960 24.67 25.9 9.8
5480 30.31 27.5 6
5000 24.39 25.1 4.5
4520 20 23.1 1.5
4480 15.94 21.2 12
4560 15.61 21.2 12
4560 15.69 21.6 12
4520 16.06 21.6 12
4480 15.56 21.2 12
4440 15.47 21.2 21
4440 15.44 21.2 30
3160 12.61 18 0
3120 12.42 18 0.8
3120 12.53 18 0.8
3120 12.17 17.6 0
3080 12.11 17.6 0
3040 12.22 17.6 0
3040 10.28 14.5 4.5
3040 16.81 21.6 27
3120 43.92 30.2 24
3120 92.42 46.7 -3
3440 113.78 99.6 12
3840 131.19 99.6 15
4360 152.03 99.6 15
5840 212.81 99.6 15
5960 217.53 99.6 15
6080 222.86 99.6 15
6200 227.83 99.6 15
6320 232.67 99.6 15
6400 238.03 99.6 15
6520 243.69 99.6 15
6640 249.56 99.6 15
6720 254.19 99.6 15
6840 258.94 99.6 15
6920 258.81 99.6 15
7640 292.97 99.6 15
7680 296.39 99.6 15
pes whipple
one and only street twin turbo rs4 b7 in the world with 640 plus awhp and 520 awtorque at 11.7 psi
800 plus bhp
800 plus bhp
I no its a old thread but more info the better lol
Done some testing today, when first got the car it done 154 g/s,
Removed pre cats,fitted cold air feed, carbon clean, removed flaps an ported the manifold (myself) an it now dose 165 g/s this is all on stock map. Dont know if this is good lol?
154 is average for carbon'd car - 165-175 is normal for cc, and ported - with high flow filter and cold air feed getting towards the higher end - I bet your car was retarding timing before and now doesn't <beep> anything - so the extra airflow and extra timing making it loads better.
http://www.MRCtuning.com
Cheers for that doug, yes it feels loads better since doing it all pulls alot stronger.Ill be booking it in with you hopfully soon for a stage 2 map an to see what you think on how its running.Doug_S2 wrote:154 is average for carbon'd car - 165-175 is normal for cc, and ported - with high flow filter and cold air feed getting towards the higher end - I bet your car was retarding timing before and now doesn't <beep> anything - so the extra airflow and extra timing making it loads better.
How do you log this info? Do you have to have a PC with VCDS plugged in and running while you do the runs or does it record this info all the time?
You need laptop with vcds plugged in an save a logMikeFish wrote:How do you log this info? Do you have to have a PC with VCDS plugged in and running while you do the runs or does it record this info all the time?
I know this is an old thread but thought I'd dig it up again.
So, I've been watching my airflow readings on a tablet running Torque OBD app in the car.
From memory I've been seeing peaks of about 348 g/s but that is not red lining it; changing at or before 7000 rpm.
Looking at the other readings here I assume that must be both banks and would put the power at about 435bhp which is what I'd expect with my mods if it had been carbon cleaned (which it hasn't). I've had my car dyno'd twice, once at MRC and a year later at amd and they both came in within 1 or 2 bhp of each other other at around the 400bhp mark so assume that to be abot as accurate as can be from a dyno.
Now I know what all these numbers mean I'll take a proper reading next time I'm driving.
I assume that my app is jut being fed the exact same numbers as VCDS would be reading? When I get the inclination one day I will do some runs and log them with the app, then do a few more with the laptop and VCDS and see if they agree with each other.
must be 148? which is per bank
No it's definitely in the three hundreds. Went out earlier and didn't quite get to the 348, but definitely hit 320 which makes it an estimated 400bhp, exactly what the dynos read.
You can get the total airflow (both banks combined) when you use a regular OBD tool rather than VCDS. So 300+ would be correct.
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
My youtube
Users browsing this forum: Google Adsense [Bot] and 157 guests
