MAF
MAF
Hey guyz any body changed there MAF sensor and may b can tell me the part number and the price?
And is it the same with S4 MAF may b?
RE: MAF
RS4 MAF is different to S4, it is a lot larger tube. I suspect the 'guts' of the sensor are the same. Anyway the part number is 077 133 471K which is £250+, BUT if you add an X to the end of the part number it gives you an exchange item and this is only £75+Vat!!! Baragin.
HTH
HTH
Tom C
VW Golf Mk2 2.0T 20VT, GT3071R, FMIC, Hi-spec brakes, 4xxbhp MRC Mapped
B5 RS4 - RS6 hybrids, FMIC, 520bhp MRC Mapped
VW Golf Mk4 20VT, K04, AP brakes, 260bhp - SOLD
RE: MAF
Thanks man 4 the info,
but can u plz explaine 4 me whats an Exchange item? its sounds like Audi thing.
I am sorry to ask you this, but r 100% sure about the number cause it takes at least 2 weeks 2 order an item from the Stupid dealer here. So u can imagine what would happen if it comes as a wrong part.
Sorry agine and many thanks mate
cheerz
cheerz
RE: MAF
Hi,
Just order 077 133 471KX from your dealer, and once you get the new one, give them your old MAF. This is what an exchange is.
HTH,
Mihnea
HTH,
Mihnea
RE: MAF
Also means that the item has been reconditioned usually, although, while talking to somebody at Milton Keynes, it also could mean that a new sensor has been fitted to the old body, or that it is a completely new unit..........clear as mud then...
Re: RE: MAF
simple1 wrote:Also means that the item has been reconditioned usually, although, while talking to somebody at Milton Keynes, it also could mean that a new sensor has been fitted to the old body, or that it is a completely new unit..........clear as mud then...
Usually for MAFs it's brand new units, maybe old housings but the sensors are brand new
HTH,
Mihnea
RE: Re: RE: MAF
Thanks boyz, appreciate your help.
Wow Mihnea, always surprising knowledge.
R the EGTs the same or am just pushing my luck?
cheers 2 all.
cheers 2 all.
RE: Re: RE: MAF
If your MAF is shot, your EGTs are going to be much higher than with a normal MAF. If you have doubts about your MAF (poor performance), just disconnect it and run the car with the MAF unplugged. You should notice an immediate boost in performance, otherwise it means the problem is not your MAF...
HTH,
Mihnea
HTH,
Mihnea
RE: Re: RE: MAF
With it unplugged you will also get worse MPG. But performance will be back as it should be.
Tom C
RE: Re: RE: MAF
Excellent boys.
Although I have never taken a close look at it, I will try to unplug it.
Thanks allot 4 your help.
Will keep u posted.
Will keep u posted.
RE: Re: RE: MAF
Did it last night, unplugged it and went for a drive, the boost kicked back and the car didn’t go to limp mode.I have to say the car was behaving strangely when not moving like the Revs will go up and down, I guess that’s due to the unplugged MAF.
So went today to the dealer and ordered the exchange MAF sensor and cost me 120$US. They said it will take 2 to 3 weeks.
Hopefully this will solve the problem.
Thank u all for your help and support.
Special thanks 4 Stuner for his help here and in the PM.
Cheers to all.
Cheers to all.
RE: Re: RE: MAF
MAF replaced, my baby is back.
I think it all started when the K&N filter was installed and the oil from the filter damaged the MAF, so be careful guys when u go K&N.
Funny the dealer told me that what I ordered and replaced is not MAF its Air flow meter, what do u guys think?
Just wanted 2 thank u all 4 your help.
RE: Re: RE: MAF
same thing. MAF = Mass Air Flow - referred to in techogeek as Air flow meter.
glad its working again
RE: Re: RE: MAF
thanks sitas3
That’s exactly what I said 2 him, I said it must be different names for the same thing then he said NO NO like he knows everything
he even asked which one am interested in replacing so said to him just change the part I ordered
RE: Re: RE: MAF
Are MAF sensors cleaned/replaced at service? Can they be done DIY? And are there any signs to look out for if they are dirty/buggered?
Bob
Bob
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Users browsing this forum: No registered users and 85 guests
