Oil Leak where is it coming from!?
creg234
Post by creg234 » Sun Feb 08, 2015 6:54 pm
I've recently developed an oil leak that over the last 2 weeks has got gradually worse, I've had a mechanic look at it and he says the only old he can see is coming from the steering rack I've had a look myself and can see the leak coming from the rack but can't see exactly where it is coming out, what I can't get my mind around is that the power steering fluid is fine I haven't had to top it up at all it's still full, yet the engine oil is going down do surely it isn't the rack?
Any help would be appreciated
R1RS4
Re: Oil Leak where is it coming from!?
Post by R1RS4 » Sun Feb 08, 2015 6:58 pm
Oil cooler pipes if they haven't been done, it's a front bumper off job
RS4 B7 Avant,2007
creg234
Post by creg234 » Sun Feb 08, 2015 7:09 pm
R1RS4 wrote:Oil cooler pipes if they haven't been done, it's a front bumper off job
Would that cause a leak to be at the back of the engine under the bulkhead it's dripping down the rack on the drivers side
RS6BRIT
Post by RS6BRIT » Sun Feb 08, 2015 7:48 pm
it could be the oil seperator, Mine was split and it leaked down the back of the engine. Just a thought. Also its not unheard of for the rocker covers to leak.
R1RS4
Post by R1RS4 » Sun Feb 08, 2015 7:52 pm
Oil under pressure in a confined space ... Can go anywhere
Your going to have to get under it, get the under tray off, torch and mirror handy and have a look
RS4 B7 Avant,2007
creg234
Post by creg234 » Sun Feb 08, 2015 7:53 pm
RS6BRIT wrote:it could be the oil seperator, Mine was split and it leaked down the back of the engine. Just a thought. Also its not unheard of for the rocker covers to leak.
The engine itself is bone dry it's behind the engine under the bulkhead, running down the gaitor of the rack on the right hand side, it can't be the rack surely
creg234
Post by creg234 » Sun Feb 08, 2015 8:00 pm
R1RS4 wrote:Oil under pressure in a confined space ... Can go anywhere
That's what we did the other day but cannot source it I'll just get him to take it apart so we can get a better view as I cannot see another way, I'd post some pics if It wasnt so dark so you could see what I mean
Post by MikeFish » Sun Feb 08, 2015 8:08 pm
The oil filter is near the back of the engine. You checked if that is tight? It's under the rear carbon engine cover.
creg234
Post by creg234 » Sun Feb 08, 2015 8:17 pm
MikeFish wrote:The oil filter is near the back of the engine. You checked if that is tight? It's under the rear carbon engine cover.
It's further back than that mike I can't get my brain around it, it's so tight to that you can't get a good view inside to have a good look
Post by MikeFish » Sun Feb 08, 2015 9:19 pm
I had an oil leak once (monkies at Audi didn't tighten the sump plug properly after a service) and it can be quite deceiving where the oil originates from given the wind from driving pushing it up and back.
NJMAudiRS4
Post by NJMAudiRS4 » Sun Feb 08, 2015 10:57 pm
I believe there is a plastic casing at the back of the block, it's possible that the seal or sealant that is used can perish over time and create an oil leak, apparently not very easy to get to and fix.
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
Users browsing this forum: Google Adsense [Bot] and 106 guests
